查看: 268|回复: 1
[求助] 机智云通用平台代码移植,手机无法连接到设备
发表于 2019-7-8 10:35:23 | 显示全部楼层 |阅读模式
各位帮忙看下是什么问题,先谢谢了
移植代码修改后如下gizwits_product.c
* @file         gizwits_product.c
* @brief        Gizwits control protocol processing, and platform-related hardware initialization
* @author       Gizwits
* @date         2017-07-19
* @version      V03030000
* @copyright    Gizwits
* @note         Gizwits is only for smart hardware
*               Gizwits Smart Cloud for Smart Products
*               Links | Value Added | Open | Neutral | Safety | Own | Free | Ecology
*               www.gizwits.com
#include <stdio.h>
#include <string.h>
#include "gizwits_product.h"
#include "usart3.h"
#include "timer.h"
#include "led.h"
#include "STM32f10x.h"
#include "usart.h"
static uint32_t timerMsCount;
/** Current datapoint */
extern dataPoint_t currentDataPoint;
/**@name Gizwits User Interface
* @brief Event handling interface
* Description:
* 1. Users can customize the changes in WiFi module status
* 2. Users can add data points in the function of event processing logic, such as calling the relevant hardware peripherals operating interface
* @param [in] info: event queue
* @param [in] data: protocol data
* @param [in] len: protocol data length
* @return NULL
* @ref gizwits_protocol.h
int8_t gizwitsEventProcess(eventInfo_t *info, uint8_t *gizdata, uint32_t len)
  uint8_t i = 0;
  dataPoint_t *dataPointPtr = (dataPoint_t *)gizdata;
  moduleStatusInfo_t *wifiData = (moduleStatusInfo_t *)gizdata;
  protocolTime_t *ptime = (protocolTime_t *)gizdata;
#if MODULE_TYPE
  gprsInfo_t *gprsInfoData = (gprsInfo_t *)gizdata;
#else
  moduleInfo_t *ptModuleInfo = (moduleInfo_t *)gizdata;
#endif
  if((NULL == info) || (NULL == gizdata))
    return -1;
  for(i=0; i<info->num; i++)
    switch(info->event)
      case EVENT_LED:
        currentDataPoint.valueLED = dataPointPtr->valueLED;
        GIZWITS_LOG("Evt: EVENT_LED %d \n", currentDataPoint.valueLED);
        if(0x01 == currentDataPoint.valueLED)
          //user handle
          LED0=1;
        else
          //user handle
          LED0=0;
        break;
      case WIFI_SOFTAP:
        break;
      case WIFI_AIRLINK:
        break;
      case WIFI_STATION:
        break;
      case WIFI_CON_ROUTER:
        break;
      case WIFI_DISCON_ROUTER:
        break;
      case WIFI_CON_M2M:
        break;
      case WIFI_DISCON_M2M:
        break;
      case WIFI_RSSI:
        GIZWITS_LOG("RSSI %d\n", wifiData->rssi);
        break;
      case TRANSPARENT_DATA:
        GIZWITS_LOG("TRANSPARENT_DATA \n");
        //user handle , Fetch data from [data] , size is [len]
        break;
      case WIFI_NTP:
        GIZWITS_LOG("WIFI_NTP : [%d-%d-%d %02d:%02d:%02d][%d] \n",ptime->year,ptime->month,ptime->day,ptime->hour,ptime->minute,ptime->second,ptime->ntp);
        break;
      case MODULE_INFO:
            GIZWITS_LOG("MODULE INFO ...\n");
      #if MODULE_TYPE
            GIZWITS_LOG("GPRS MODULE ...\n");
            //Format By gprsInfo_t
      #else
            GIZWITS_LOG("WIF MODULE ...\n");
            //Format By moduleInfo_t
            GIZWITS_LOG("moduleType : [%d] \n",ptModuleInfo->moduleType);
      #endif
    break;
      default:
        break;
  return 0;
* Data point initialization function
* In the function to complete the initial user-related data
* @param none
* @return none
* @note The developer can add a data point state initialization value within this function
void userInit(void)
  LED_Init();
  uart_init(115200);
  memset((uint8_t*)&currentDataPoint, 0, sizeof(dataPoint_t));
    /** Warning !!! DataPoint Variables Init , Must Within The Data Range **/
* @brief  gizTimerMs
* millisecond timer maintenance function ,Millisecond increment , Overflow to zero
* @param none
* @return none
void gizTimerMs(void)
    timerMsCount++;
* @brief gizGetTimerCount
* Read system time, millisecond timer
* @param none
* @return System time millisecond
uint32_t gizGetTimerCount(void)
    return timerMsCount;
* @brief mcuRestart
* MCU Reset function
* @param none
* @return none
void mcuRestart(void)
  __set_FAULTMASK(1);//关闭所有中断
    NVIC_SystemReset();//复位
* @brief TIMER_IRQ_FUN
* Timer Interrupt handler function
* @param none
* @return none
void TIMER_IRQ_FUN(void)
    if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //¼ÏÔ´
                TIM_ClearITPendingBit(TIM3, TIM_IT_Update  );  //
                gizTimerMs();
* @brief UART_IRQ_FUN
* UART Serial interrupt function ,For Module communication
* Used to receive serial port protocol data between WiFi module
* @param none
* @return none
void UART_IRQ_FUN(void)
        u8 res;
        if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET)//
                res =USART_ReceiveData(USART3);
                gizPutData(&res, 1);//
* @brief uartWrite
* Serial write operation, send data to the WiFi module
* @param buf      : Data address
* @param len       : Data length
* @return : Not 0,Serial send success;
*           -1,Input Param Illegal
int32_t uartWrite(uint8_t *buf, uint32_t len)
    uint32_t i = 0;
    if(NULL == buf)
        return -1;
    #ifdef PROTOCOL_DEBUG
    GIZWITS_LOG("MCU2WiFi[%4d:%4d]: ", gizGetTimerCount(), len);
    for(i=0; i<len; i++)
        GIZWITS_LOG("%02x ", buf);
    GIZWITS_LOG("\n");
    #endif
        //USART_SendData(UART, buf);//STM32 test demo
        //Serial port to achieve the function, the buf sent to the module
        USART_SendData(USART3,buf);
        while(USART_GetFlagStatus(USART3,USART_FLAG_TC)==RESET); //循环发送,直到发送完毕
        if(i >=2 && buf == 0xFF)
          //Serial port to achieve the function, the 0x55 sent to the module
          //USART_SendData(UART, 0x55);//STM32 test demo
          USART_SendData(USART3,0x55);
    return len;
主函数main.c代码如下
#include "led.h"
#include "delay.h"
#include "sys.h"
#include "timer.h"
#include "usart3.h"
#include "usart.h"
//ЭÒé³õʼ»¯
void Gizwits_Init(void)
        TIM3_Int_Init(9,7199);//1MSϵͳ¶¨Ê±
   usart3_init(115200);//WIFI³õʼ»¯
        memset((uint8_t*)&currentDataPoint, 0, sizeof(dataPoint_t));//É豸״̬½á¹¹Ìå³õʼ»¯
        gizwitsInit();//»º³åÇø³õʼ»¯
//Êý¾Ý²É¼¯
void userHandle(void)
    //Åжϵ±Ç°LED1¿ª¹ØÁ¿
            if(LED1==0)
            currentDataPoint.valueLED = 1;
      else
            currentDataPoint.valueLED = 0;
int main(void)
        delay_init();                     //ÑÓʱº¯Êý³õʼ»¯
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);// ÉèÖÃÖжÏÓÅÏȼ¶·Ö×é2
        LED_Init();                          //³õʼ»¯ÓëLEDÁ¬½ÓµÄÓ²¼þ½Ó¿Ú
  uart_init(115200);
  Gizwits_Init();
           while(1)
    userHandle();
    gizwitsHandle((dataPoint_t *)&currentDataPoint);//ЭÒé´¦Àí
                LED1=!LED1;
                delay_ms(1000);
发表于 2019-7-10 19:49:28 | 显示全部楼层
不合法的数据太多了
delay_ms(1000);       这种代码放在while是绝对禁止的
发烧友
