查看: 4634|回复: 0
[求助] 大佬们,这是什么错误,日志说获知本地信息失....
发表于 2019-10-30 16:49:02 | 显示全部楼层 |阅读模式
用的是esp8266 01模块
Auth] GAgentAuthInit : start ...
[030464][Dev]  Get gagent config data from master eare.
[030464][Dev]  Save gagent config data
[Auth] gagentReqAuthKey ...
[029432][Dev] uart sendLen:40 ok.
[029432][Local] uartSendData 822 Time:327767 - 327
[029432][Local] uartSendData cmd=69 GAGENT2MCU_AUTHKEY_REQ|MCU2GAGENT_AUTHKEY_ACK need't resent
[Auth] wait auth tool ack ...
mode : sta(50:02:91:b0:15:f3)
add if0
[Auth] gagentAuthTimeOutCb authMode ack timeout !!!
[028296][Dev] sizeof(pgContextData->gc.Ursvd.rsvd_st) : 244 result=1.
[028296][Dev] Domain:api.gizwits.com:80.
[028296][Dev] tz in sec:28800,timezone:8.0
[028232][NWK] NWK_WIFI_ONBOARDING_UP
SC version: V2.5.4
[027768][WiFiEvent] OpenAirlink...
[027768][Dev] uart sendLen:9 ok.
[027768][Local] GAgent_LocalInit OK!
[027768][LanOTA] lanOTAInit ...... ok
[027720][Simulator] GAgent lib Time:Jun  9 2018 14:42:04
[027720][GAgent] GAgent Start...
[027720][Local] ----------------------------------------- GAGENT INFO --------------------------------------
[027720][Local] GAgent Work in GAGENT_STANDARD.
[027720][Local] GAgent Product Soft Version: 04020034. Hard Version: 00ESP826
[027720][Local] GAgent Compiled Time: Jun  9 2018, 14:42:08.
[027720][Local] GAgent cache first ssid .
[027720][Local] GAgent backup ssid .
[027720][Local] GAgent mac :500291B015F3
[027720][Local] GAgent authKey : [027720][Local] GAgent passcodelen:10 : BM****MK
[027720][Local] GAgent did :NULL
[027720][Local] GAgent old passcode: NULL
[027720][Local] GAgent old_did: NULL
[027720][Local] GAgent old pk : len:0
[027720][Local] GAgent AP name:XPG-GAgent-15F3
[027720][Local] GAgent 3rd cloud :
[027720][Local] GAgent M2M Host : , IP :0.0.0.0
[027720][Local] GAgent Default GServer Host :api.gizwits.com port:80
[027720][Local] GAgent GService Host : , Port :0 , IP :0.0.0.0
[027720][Local] GAgent BizLogLev:00,SysLogLev:00
[027720][Local] GAgent MCU Protocol Vertion:.
[027720][Local] GAgent MCU P0 Vertion:.
[027720][Local] GAgent MCU Hard Vertion:.
[027720][Local] GAgent MCU Soft Vertion:.
[027720][Local] GAgent WeChat Device Type: gh_35****ab57
[027720][Local] Flash Size:FLASH_SIZE_8Mbit .
[027720][Local] --------------------------------------------------------------------------------------
[027560][NWK] gagentNwkEventCB event: 0x0040
[027560][Local] GAgentStatus change, lastGAgentStatus:0x0000, newGAgentStatus:0x0004
[027424][Local] Local send list node cnt 1
[027424][Local] Local is busy,will be sent for a while
[027424][FR]  Cancle router connect monitor.
[027424][Dev]  Save gagent config data
[027424][NWK] haiNwkStatus: 0x000C, gagentStatus: 0x0004
[027224][Local] BaudRate : 9600
[027224][Dev] uart sendLen:9 ok.
[027224][Local] Local_UartRx_Timer resendTime = 1
[027064][Local] BaudRate : 9600
[027064][Dev] uart sendLen:9 ok.
[027064][Local] Local_UartRx_Timer resendTime = 2
[026584][Local] BaudRate : 9600
[026584][Dev] uart sendLen:9 ok.
[026584][Local] Local_UartRx_Timer resendTime = 3
[025624][Local] BaudRate : 9600
[025624][Dev] uart sendLen:9 ok.
[025624][Local] Local_UartRx_Timer resendTime = 4
scandone
[024952][Local] BaudRate : 9600
[024952][Dev] uart sendLen:9 ok.
[024952][Local] Local_UartRx_Timer resendTime = 5
[024552][Local] BaudRate : 9600
[024552][Dev] uart sendLen:9 ok.
[024552][Local] Local_UartRx_Timer resendTime = 6
[024232][Local] BaudRate : 9600
[024232][Dev] uart sendLen:9 ok.
[024232][Local] Local_UartRx_Timer resendTime = 7
[023432][Local] BaudRate : 9600
[023432][Dev] uart sendLen:9 ok.
[023432][Local] Local_UartRx_Timer resendTime = 8
[024616][Local] BaudRate : 9600
[024616][Dev] uart sendLen:9 ok.
[024616][Local] Local_UartRx_Timer resendTime = 19
[024616][Local]  GAgent get local info fail ...
[024616][Local]  Please check your local data,and restart GAgent again !!
[024616][Dev] gagentDevRestart 1176 GAGENT_RESTART_DIRECT
[024616][Dev] some net err occur,do nothing !!!
[024616][Dev] Please restart GAgent !!!
