查看: 27252|回复: 1
[求助] 用机智云自动生成安卓源码工程导入eclipse错误
 楼主| 发表于 2020-7-3 11:22:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
console:错误(红色字体)
[2020-07-03 11:12:45 - GOpenSource_AppKit] invalid resource directory name: F:\Android\eclipse\ANDROID_PROJECT\appcompat-v7-25.1.0\res/values-b+sr+Latn
[2020-07-03 11:12:47 - design-25.3.0] invalid resource directory name: F:\Android\eclipse\ANDROID_PROJECT\appcompat-v7-25.1.0\res/values-b+sr+Latn
[2020-07-03 11:12:48 - GOpenSource_AppKit] invalid resource directory name: F:\Android\eclipse\ANDROID_PROJECT\appcompat-v7-25.1.0\res/values-b+sr+Latn
[2020-07-03 11:12:50 - design-25.3.0] invalid resource directory name: F:\Android\eclipse\ANDROID_PROJECT\appcompat-v7-25.1.0\res/values-b+sr+Latn
[2020-07-03 11:12:51 - GOpenSource_AppKit] invalid resource directory name: F:\Android\eclipse\ANDROID_PROJECT\appcompat-v7-25.1.0\res/values-b+sr+Latn
problems:3种错误类型
1:invalid resoure directory name
2.The container 'Android Dependencies' references non existing library 'F:\Android\eclipse\ANDROID_PROJECT\appcompat-v7-25.1.0\bin\appcompat-v7-25.1.0.jar' design-25.3.0  Build path Build Path Problem
3.The project cannot be built until build path errors are resolved GOpenSource_AppKit  Unknown Java Problem
4.Unparsed aapt error(s)! Check the console for output. GOpenSource_AppKit  line 1 Android ADT Problem
发表于 2020-9-11 11:46:02 | 只看该作者
顶起来,怎么没有人回复的?
