查看: 26564|回复: 1
[求助] 有两个日志,是烧的同一个程序的二块板子(ESP8266 SOC),但...
 楼主| 发表于 2020-7-26 11:10:24 | 显示全部楼层 |阅读模式
,能有两个日志,是烧的同一个程序的二块板子(esp8266  SOC),但是日志却不一样 ,能否帮助我分析一下,谢谢!第一块模块烧写后,能正常工作,其日志如下
---------------SDK version:2.0.0(5a875ba)--------------
system_get_free_heap_size=32672
reset reason: 6
---UPGRADE_FW_BIN1---
gpio_name 0
gpio_name 5
[Auth] GAgentAuthInit : start ...
[026040][Dev]  Get gagent config data from master eare.
[026040][Dev]  Save gagent config data
[Auth] gagentReqAuthKey ...
[025008][Dev] uart sendLen:40 ok.
[025008][Local] uartSendData 822 Time:192054 - 191
[025008][Local] uartSendData cmd=69 GAGENT2MCU_AUTHKEY_REQ|MCU2GAGENT_AUTHKEY_ACK need't resent
[Auth] wait auth tool ack ...
[025008][Dev] Domain:api.gizwits.com:80.
[025008][Dev] tz in sec:28800,timezone:8.0
[024944][WiFiEvent] In Station mode
[024944][WiFiEvent] SSID:CMCC-nRKg,KEY:fchx6tke
[024944][WiFiEvent]  Wifi station connect failed!
[024944][NWK] NWK_WIFI_STA_UP
[024944][LanOTA] lanOTAInit ...... ok
[024896][Simulator] GAgent lib Time:Apr  3 2018 18:43:47
[024896][GAgent] GAgent Start...
[024896][Local] ----------------------------------------- GAGENT INFO --------------------------------------
[024896][Local] GAgent Work in GAGENT_SOC.
[024896][Local] GAgent Product Soft Version: 04020825. Hard Version: 00ESP826
[024896][Local] GAgent Compiled Time: Apr  3 2018, 18:43:49.
[024896][Local] GAgent cache first ssid CMCC-nRKg.
[024896][Local] GAgent backup ssid .
[024896][Local] GAgent mac :600194378C64
[024896][Local] GAgent authKey : [024896][Local] GAgent passcodelen:10 : VJ****JV
[024896][Local] GAgent did :NULL
[024896][Local] GAgent old passcode: NULL
[024896][Local] GAgent old_did: NULL
[024896][Local] GAgent old pk :ecc7f352df4a46e9bda646eff117efc8 len:32
第二块模块烧写后,配置不了、不能正常工作,其日志如下:
reset reason: 6
gpio_name 0
gpio_name 5
[Auth] gagentAuthInit : start ...
[025008][Local] uartSendData 822 Time:160104 - 160
[024944][NWK] NWK_WIFI_ONBOARDING_UP
SC version: V2.5.4
[024680][WiFiEvent] OpenAirlink...
[024680][LanOTA] lanOTAInit ...... ok
[024632][Simulator] GAgent lib Time:Apr  3 2018 18:43:47
[024632][GAgent] GAgent Start...
[024632][Local] ----------------------------------------- GAGENT INFO --------------------------------------
[024632][Local] GAgent Work in GAGENT_SOC.
[024632][Local] GAgent Product Soft Version: 04020825. Hard Version: 00ESP826
[024632][Local] GAgent Compiled Time: Apr  3 2018, 18:43:49.
[024632][Local] GAgent cache first ssid .
[024632][Local] GAgent backup ssid .
[024632][Local] GAgent mac :500291E9B2AF
[024632][Local] GAgent authKey : [024632][Local] GAgent passcodelen:10 : QC****MW
[024632][Local] GAgent did :NULL
[024632][Local] GAgent old passcode: NULL
[024632][Local] GAgent old_did: NULL
[024632][Local] GAgent old pk :ecc7f352df4a46e9bda646eff117efc8 len:32
[024632][Local] GAgent AP name:XPG-GAgent-B2AF
个人觉得是第二块模块板配置参数没有读出来(与第一块板日志红字比较),但不知是什么原因。是按步骤操作的。
发表于 2020-7-29 14:49:52 | 显示全部楼层
一个配网了,一个没配网
发烧友
