楼主: bigfanofloT
[资料] 从0开始玩转Gokit3 SOC(3)温湿度远程监控应用-数值量上报
发表于 2017-10-9 03:31:36 | 显示全部楼层
bigfanofloT 发表于 2017-10-1 17:13
把你的发上来看看
这个就是系统自动生成的新代码,未按照该贴编辑前可以编译,按照该贴修改以后报错无法编译,谢谢。
* @file         user_main.c
* @brief        The program entry file
* @author       Gizwits
* @date         2017-07-19
* @version      V03030000
* @copyright    Gizwits
* @note         机智云.只为智能硬件而生
*               Gizwits Smart Cloud  for Smart Products
*               链接|增值ֵ|开放|中立|安全|自有|自由|生态
*               www.gizwits.com
#include "ets_sys.h"
#include "osapi.h"
#include "user_interface.h"
#include "gagent_soc.h"
#include "user_devicefind.h"
#include "user_webserver.h"
#include "gizwits_product.h"
#include "driver/hal_key.h"
#if ESP_PLATFORM
#include "user_esp_platform.h"
#endif
#ifdef SERVER_SSL_ENABLE
#include "ssl/cert.h"
#include "ssl/private_key.h"
#else
#ifdef CLIENT_SSL_ENABLE
unsigned char *default_certificate;
unsigned int default_certificate_len = 0;
unsigned char *default_private_key;
unsigned int default_private_key_len = 0;
#endif
#endif
/**@name User timers related parameters
#define USER_TIME_MS 1000                                                   ///< Timing time in milliseconds
LOCAL os_timer_t userTimer;                                                 ///< User timer structure
/**@name Key related definitions
#define GPIO_KEY_NUM                            2                           ///< Defines the total number of key members
#define KEY_0_IO_MUX                            PERIPHS_IO_MUX_GPIO0_U      ///< ESP8266 GPIO function
#define KEY_0_IO_NUM                            0                           ///< ESP8266 GPIO number
#define KEY_0_IO_FUNC                           FUNC_GPIO0                  ///< ESP8266 GPIO name
#define KEY_1_IO_MUX                            PERIPHS_IO_MUX_MTMS_U       ///< ESP8266 GPIO function
#define KEY_1_IO_NUM                            14                          ///< ESP8266 GPIO number
#define KEY_1_IO_FUNC                           FUNC_GPIO14                 ///< ESP8266 GPIO name
LOCAL key_typedef_t * singleKey[GPIO_KEY_NUM];                              ///< Defines a single key member array pointer
LOCAL keys_typedef_t keys;                                                  ///< Defines the overall key module structure pointer
* Key1 key short press processing
* @param none
* @return none
LOCAL void ICACHE_FLASH_ATTR key1ShortPress(void)
    GIZWITS_LOG("#### KEY1 short press ,Production Mode\n");
    gizwitsSetMode(WIFI_PRODUCTION_TEST);
* Key1 key presses a long press
* @param none
* @return none
LOCAL void ICACHE_FLASH_ATTR key1LongPress(void)
    GIZWITS_LOG("#### key1 long press, default setup\n");
    gizwitsSetMode(WIFI_RESET_MODE);
* Key2 key to short press processing
* @param none
* @return none
LOCAL void ICACHE_FLASH_ATTR key2ShortPress(void)
    GIZWITS_LOG("#### key2 short press, soft ap mode \n");
* Key2 button long press
* @param none
* @return none
LOCAL void ICACHE_FLASH_ATTR key2LongPress(void)
    GIZWITS_LOG("#### key2 long press, airlink mode\n");
* Key to initialize
* @param none
* @return none
LOCAL void ICACHE_FLASH_ATTR keyInit(void)
    singleKey[0] = keyInitOne(KEY_0_IO_NUM, KEY_0_IO_MUX, KEY_0_IO_FUNC,
                                key1LongPress, key1ShortPress);
    singleKey[1] = keyInitOne(KEY_1_IO_NUM, KEY_1_IO_MUX, KEY_1_IO_FUNC,
                                key2LongPress, key2ShortPress);
    keys.singleKey = singleKey;
    keyParaInit(&keys);
* @brief user_rf_cal_sector_set
* Use the 636 sector (2544k ~ 2548k) in flash to store the RF_CAL parameter
* @param none
* @return none
uint32_t ICACHE_FLASH_ATTR user_rf_cal_sector_set()
    return 636;
* @brief program entry function
* In the function to complete the user-related initialization
* @param none
* @return none
void ICACHE_FLASH_ATTR user_init(void)
    uint32_t system_free_size = 0;
    wifi_station_set_auto_connect(1);
    wifi_set_sleep_type(NONE_SLEEP_T);//set none sleep mode
    espconn_tcp_set_max_con(10);
    uart_init_3(9600,115200);
    UART_SetPrintPort(1);
    GIZWITS_LOG( "---------------SDK version:%s--------------\n", system_get_sdk_version());
    GIZWITS_LOG( "system_get_free_heap_size=%d\n",system_get_free_heap_size());
    struct rst_info *rtc_info = system_get_rst_info();
    GIZWITS_LOG( "reset reason: %x\n", rtc_info->reason);
    if (rtc_info->reason == REASON_WDT_RST ||
        rtc_info->reason == REASON_EXCEPTION_RST ||
        rtc_info->reason == REASON_SOFT_WDT_RST)
        if (rtc_info->reason == REASON_EXCEPTION_RST)
            GIZWITS_LOG("Fatal exception (%d):\n", rtc_info->exccause);
        GIZWITS_LOG( "epc1=0x%08x, epc2=0x%08x, epc3=0x%08x, excvaddr=0x%08x, depc=0x%08x\n",
                rtc_info->epc1, rtc_info->epc2, rtc_info->epc3, rtc_info->excvaddr, rtc_info->depc);
    if (system_upgrade_userbin_check() == UPGRADE_FW_BIN1)
        GIZWITS_LOG( "---UPGRADE_FW_BIN1---\n");
    else if (system_upgrade_userbin_check() == UPGRADE_FW_BIN2)
        GIZWITS_LOG( "---UPGRADE_FW_BIN2---\n");
    keyInit();
    userInit();
    gizwitsInit();
    //user timer
    os_timer_disarm(&userTimer);
    os_timer_setfn(&userTimer, (os_timer_func_t *)userHandle, NULL);
    os_timer_arm(&userTimer, USER_TIME_MS, 1);
    GIZWITS_LOG("--- system_free_size = %d ---\n", system_get_free_heap_size());
发表于 2017-10-9 03:35:51 | 显示全部楼层
把你的发上来看看
gen_misc.sh version 20150511
boot mode: new
app:1
spi speed: 40 MHz
spi mode: QIO
spi_size_map:6
make[1]: Entering directory '/home/cobetckoe/workspace/logive/app/user'
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../..//app/gagent/inc -I ../..//app/Gizwits -I ../..//app/Utils user_json.c
/bin/sh: 2: cannot create .output/eagle/debug/obj/user_json.d.26294: Permission denied
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../include -I ../../include -I ../../include/eagle -I ../..//app/gagent/inc -I ../..//app/Gizwits -I ../..//app/Utils user_main.c
/bin/sh: 2: cannot create .output/eagle/debug/obj/user_main.d.26299: Permission denied
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -ffunction-sections -fdata-sections   -DICACHE_FLASH   -I include -I ./ -I ../../include/ets -I ../include  -I ../../include -I ../../include/eagle -I ../..//app/gagent/inc -I ../..//app/Gizwits -I ../..//app/Utils  -o .output/eagle/debug/obj/user_main.o -c user_main.c
user_main.c: In function 'user_rf_cal_sector_set':
user_main.c:152:30: error: 'dataPoint_t' has no member named 'valuetemp'
              currentDataPoint.valuetemp = curTemperature;
user_main.c:153:30: error: 'dataPoint_t' has no member named 'valuehum'
              currentDataPoint.valuehum = curHumidity;
../../Makefile:321: recipe for target '.output/eagle/debug/obj/user_main.o' failed
make[1]: ** [.output/eagle/debug/obj/user_main.o] Error 1
make[1]: Leaving directory '/home/cobetckoe/workspace/logive/app/user'
../Makefile:307: recipe for target '.subdirs' failed
make: ** [.subdirs] Error 2
发表于 2017-10-20 10:20:39 | 显示全部楼层
在user_main.c 里找不着userTimerFunc这个函数,难道我下载的姿势不对,先下载源码下来学习下,谢谢!
//user timer
如果是这个userHandle,却又是在gizwits_product.c中
发表于 2017-10-23 15:03:59 | 显示全部楼层
快看快看快看快看
5
发表于 2017-10-27 14:30:08 | 显示全部楼层
看看这样子的
8
发表于 2017-10-29 13:24:47 | 显示全部楼层
学习学习下
发表于 2017-11-1 21:15:51 | 显示全部楼层
初学者 用处很大
发表于 2017-11-9 11:08:19 | 显示全部楼层
谢谢 正在学习中
发表于 2017-11-24 12:40:32 | 显示全部楼层
66666666666666666666xiexie
发表于 2017-12-5 13:38:06 | 显示全部楼层
学习学习学习学习学习学习
发表于 2017-12-7 00:43:54 | 显示全部楼层
hiHLEEGFGDSD
10
发表于 2017-12-12 21:49:51 | 显示全部楼层
很详细 希望可以继续更新
发表于 2017-12-29 10:25:58 | 显示全部楼层
好资料收下先
