查看: 23697|回复: 1
[求助] 新人求助开发问题
发表于 2017-8-21 10:17:49 | 显示全部楼层 |阅读模式
请问一下为什么以下错误是什么引起的?是我的SDK没配好吗
[2017-08-21 10:13:43 - GOpenSource_AppKit] adb is running normally.
[2017-08-21 10:13:43 - GOpenSource_AppKit] Performing com.gizwits.opensource.appkit.UserModule.GosUserLoginActivity activity launch
[2017-08-21 10:13:43 - GOpenSource_AppKit] Automatic Target Mode: Unable to detect device compatibility. Please select a target device.
[2017-08-21 10:13:51 - GOpenSource_AppKit] Uploading GOpenSource_AppKit.apk onto device 'b64eefa'
[2017-08-21 10:13:53 - GOpenSource_AppKit] Installing GOpenSource_AppKit.apk...
[2017-08-21 10:13:55 - GOpenSource_AppKit] Installation error: INSTALL_CANCELED_BY_USER
[2017-08-21 10:13:55 - GOpenSource_AppKit] Please check logcat output for more details.
[2017-08-21 10:13:55 - GOpenSource_AppKit] Launch canceled!
[2017-08-21 10:14:17 - GOpenSource_AppKit] ------------------------------
[2017-08-21 10:14:17 - GOpenSource_AppKit] Android Launch!
[2017-08-21 10:14:17 - GOpenSource_AppKit] adb is running normally.
[2017-08-21 10:14:17 - GOpenSource_AppKit] Performing com.gizwits.opensource.appkit.UserModule.GosUserLoginActivity activity launch
[2017-08-21 10:14:17 - GOpenSource_AppKit] Automatic Target Mode: using device 'b64eefa'
[2017-08-21 10:14:17 - GOpenSource_AppKit] Uploading GOpenSource_AppKit.apk onto device 'b64eefa'
[2017-08-21 10:14:19 - GOpenSource_AppKit] Installing GOpenSource_AppKit.apk...
[2017-08-21 10:14:21 - GOpenSource_AppKit] Installation error: INSTALL_CANCELED_BY_USER
[2017-08-21 10:14:21 - GOpenSource_AppKit] Please check logcat output for more details.
[2017-08-21 10:14:21 - GOpenSource_AppKit] Launch canceled!
34
超级版主
发表于 2017-8-21 15:30:19 | 显示全部楼层
重新拔插手机试试,重启ADB试试,手机是否开启了USB调试,手机是否信任未知软件的安装
