查看: 11434|回复: 2
硬件接入失败
发表于 2018-2-23 00:23:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
日志如下:
connected with 涓浗鑱旈€ channel 9
dhcp client start...
[025792][WiFiEvent] connect to ssid xxx€ channel 9
[026280][Local] BaudRate : 9600
[026280][Dev] uart sendLen:9 ok.
[026280][Local] Local_UartRx_Timer resendTime = 5
[026280][Local] Local_UartRx_Timer resendTime = 6
ip:192.168.199.172,mask:255.255.255.0,gw:192.168.199.1
[025984][WiFiEvent] ip:192.168.199.172,mask:255.255.255.0,gw:192.168.199.1
[025984][NWK] NWK_WIFI_STA_CONNECTED
[026280][NWK] GAgentNwkEventCB event: 0x0010
[026280][Local] GAgentStatus change, lastGAgentStatus:0x0002, newGAgentStatus:0x0012
[..MALLOC 0x3fff5848] add2UartBufList[103] len=112
[..MALLOC 0x3fff3418] add2UartBufList[112] len=2
[026136][Local] Local send list node cnt 2
[026136][Local] Local is busy,will be sent for a while
[025976][WiFiEvent] enable bind mode, timeout time: 0.
[025976][GServer]  Not ip, Go to GServer DNS.
[025976][FR]  dns: api.gizwits.com found null obj. idex: 0
[025976][FR] dns data -------------------
[025976][FR] dns num:0
[025976][FR] domain:api.gizwits.com
[025976][FR] ip:
[025976][FR] reReqTime:0
[025976][FR] timeout:3600
[025976][FR] lastReqTime:4
[025976][FR] dnsResult_Cb:0x4021b438
只连上一次后就再也连接不上了!
34
超级版主
发表于 2018-2-23 10:39:43 | 只看该作者
可以提供一下上电开始的完整日志么
 楼主| 发表于 2018-2-26 22:48:42 | 只看该作者
附件中是抓取的日志,好像在无限启动中.
我只是简单编辑了gizwits_product.c中的userInit和userHandle。
log.txt.zip
1.82 KB, 下载次数: 0, 下载积分: 威望 1
