查看: 2129|回复: 1
[求助] 8266的SOC方案,手机点击下发过快时候会导致8266重启。。。
发表于 2018-6-13 23:48:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
昨晚在新建数据点后,MCU开发选择8266的soc方案,现在已经成功烧录到8266并且成功运行,但是当手机快速下发时候,设备会重启,打印见下面的黑色加粗字体信息!
在以前的自动生成的代码里面,是没有这情况的!!
型号:8266-12e  32Mbit
工程固件版本信息:
  1. <p>/**
  2. * MCU software version number
  3. */
  4. #define SOFTWARE_VERSION                        "03030000"</p><p>/**
  5. * MCU hardware version number
  6. */
  7. #define HARDWARE_VERSION                        "03000001"</p><p> </p>
串口打印信息:
  1. [23:45:48.126] ~~~issued data: [014776][M2M] send_packet len=70
  2. [23:45:48.176] [014776][GAgent] Add data to send buffer list,waiting to be sent.destPd:1
  3. [23:45:48.253] [014560][GAgent] Need to send bufCount = 5
  4. [23:45:48.297] [015968][Simulator] gagentDataReceived exit
  5. [23:45:48.345] [015968][GAgent] CLOUD_DATA_IN cmd : 0093
  6. [23:45:48.396] [015968][Simulator] 1.gagentDataReceived from Cloud len=76 addr:0x3fff8270 pos:0x3fff81a8
  7. [23:45:48.486]
  8. [23:45:48.486]
  9. [23:45:48.486] [014768][Simulator] 2.gagentDataReceived from Cloud len=76 addr:0x3fff8270 pos:0x3fff81a8
  10. [23:45:48.586]
  11. [23:45:48.586]
  12. [23:45:48.586] [
  13. [23:45:48.596] 014768][Simulator] gagentDataReceived msg Cloud did:HdaT948DmCYrDQ2nJLSi4A szClientid:usruVj8WUHokaPEAqd3QGtj
  14. [23:45:48.706] ~~~gizIssuedProcess: did is NULL .
  15. [23:45:48.746] ~~~issued data: [014768][M2M] send_packet len=70
  16. [23:45:48.796] [014768][GAgent] Add data to send buffer list,waiting to be sent.destPd:1
  17. [23:45:48.876] [014568][GAgent] Need to send bufCount = 6
  18. [23:45:48.916] [015976][Simulator] gagentDataReceived exit
  19. [23:45:48.967] [015976][GAgent] CLO%謧!匇1)=羰乍仂)>        H9鼈,>
  20. [23:45:49.096] x┅┅┅┅┅┅iE-乿ersion:2.0.0(5a875ba)--------------
  21. [23:45:49.156] system_get_free_heap_size=33272
  22. [23:45:49.186] reset reason: 3
  23. [23:45:49.206] epc1=0x40101ac0, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
  24. [23:45:49.296] ---UPGRADE_FW_BIN1---
  25. [23:45:49.326] gpio_name 14
  26. [23:45:49.337] gpio_name 12
  27. [23:45:49.356] gpio_name 13
  28. [23:45:49.366] [Auth] gagentAuthInit : start ...
  29. [23:45:49.406] [026616][Dev]  Get gagent config data from master eare.
  30. [23:45:49.466] [026616][Dev]  Save gagent config data
  31. [23:45:49.506] [Auth] GAgent SOC had did don't need to get authkey!!!
  32. [23:45:49.566] [Auth] gagentAuthInit :
  33. [23:45:49.596] end ...
  34. [23:45:49.596] devAuthResultCb result=0
  35. [23:45:49.626] [025584][Dev] Domain:api.gizwits.com:80.
  36. [23:45:49.667] [025584][Dev] tz in sec:28800,timezone:8.0
超级版主
发表于 2018-6-14 17:03:54 | 只看该作者
你把完整日志保存txt上传上来帖子。如果手机1秒下发控制4/5次甚至更频繁给8266,会造成WiFi模块重启
