查看: 12516|回复: 2
在stm32下位机上怎样获得app上数据透传的数据?
10
发表于 2018-6-20 20:27:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#芯片STM32407
#使用的Mcu生成文件,数据点实现的数据透传
     在app上我用的机智云的例程如下:
  1. byte[] input1 = { 0x11, 0x22, 0x33, 0x44, 0x55, 0x66, 0x77 };
  2. // byte[] input2 = { 11, 22, 33, 44, 55, 66, 77, 88, 99};
  3. ConcurrentHashMap<String, Object> dataMap = new ConcurrentHashMap<String, Object>();
  4. dataMap.put("kuozhan", input1);
  5. device.write(dataMap, 0);
然后在stm32下位机上怎么的到这个透传数据?或者说下面的数据点里哪个是表示透传的?
  1. /** Event enumeration */
  2. typedef enum
  3. {
  4.   WIFI_SOFTAP = 0x00,                               ///< WiFi SOFTAP configuration event
  5.   WIFI_AIRLINK,                                     ///< WiFi module AIRLINK configuration event
  6.   WIFI_STATION,                                     ///< WiFi module STATION configuration event
  7.   WIFI_OPEN_BINDING,                                ///< The WiFi module opens the binding event
  8.   WIFI_CLOSE_BINDING,                               ///< The WiFi module closes the binding event
  9.   WIFI_CON_ROUTER,                                  ///< The WiFi module is connected to a routing event
  10.   WIFI_DISCON_ROUTER,                               ///< The WiFi module has been disconnected from the routing event
  11.   WIFI_CON_M2M,                                     ///< The WiFi module has a server M2M event
  12.   WIFI_DISCON_M2M,                                  ///< The WiFi module has been disconnected from the server M2M event
  13.   WIFI_OPEN_TESTMODE,                               ///< The WiFi module turns on the test mode event
  14.   WIFI_CLOSE_TESTMODE,                              ///< The WiFi module turns off the test mode event
  15.   WIFI_CON_APP,                                     ///< The WiFi module connects to the APP event
  16.   WIFI_DISCON_APP,                                  ///< The WiFi module disconnects the APP event
  17.   WIFI_RSSI,                                        ///< WiFi module RSSI event
  18.   WIFI_NTP,                                         ///< Network time event
  19.   MODULE_INFO,                                      ///< Module information event
  20.   TRANSPARENT_DATA,                                 ///< Transparency events
  21.   EVENT_LEDonoff,
  22.   EVENT_main_password,
  23.   EVENT_TYPE_MAX                                    ///< Enumerate the number of members to calculate (user accidentally deleted)
  24. } EVENT_TYPE_T;
15
发表于 2018-6-20 22:41:31 | 只看该作者
现在板子没有在手上,印象中是可以通过串口打印输出的方式看到APP下发的透传数据,在你的设备已经上线的情况下,你试试看行不行。
那有没有接受这个透传数据的“”信号“”,在上位机传来这个透传数据时,单片机做出一些响应  详情 回复 发表于 2018-6-22 16:41
10
 楼主| 发表于 2018-6-22 16:41:47 | 只看该作者
Seasonic 发表于 2018-6-20 22:41
现在板子没有在手上,印象中是可以通过串口打印输出的方式看到APP下发的透传数据,在你的设备已经上线的情 ...
