查看: 9900|回复: 0
[问答] 新手,求助
发表于 2018-11-6 21:24:06 | 显示全部楼层 |阅读模式
单片机纯新手,网上自学,一周时间,连抄带试。
突发奇想,想做个双路温度控制器。结果发现自己水平不行,下边代码大部分抄来的。特来求助。
UNO的A2~A5脚是设定按钮,想用这四个按钮分别改变温度设定的值(varR_set1,varR_set2).应该是代码部分有问题,C语言不懂,网上查教程,看得迷迷糊糊。请各高手给我指点迷津。
* @file         Gizwits + arduinoUnoR3 Library
* @brief        Datapoints handle , Gizwits Process
* @author       Gizwits
* @date         2017-08-01
* @version      V03030000
* @copyright    Gizwits
* @note         机智云.只为智能硬件而生
*               Gizwits Smart Cloud  for Smart Products
*               链接|增值ֵ|开放|中立|安全|自有|自由|生态
*               www.gizwits.com
#include "Gizwits.h"
#include <Wire.h>
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
int jdq1pin = 10;
int jdq2pin = 11;
int led1pin = 12;
int led2pin = 13;
int temup1 = A3;
int temdw1 = A2;
int temup2 = A5;
int temdw2 = A4;
int sensorValue1 = 0;
int sensorValue2 = 0;
unsigned long varR_set1 = 0;
unsigned long varR_set2 = 0;
float wendu1;
float wendu2;
// 初始化针脚
const int rs = 9, en = 8, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
Gizwits myGizwits;
#define   KEY1              6
#define   KEY2              7
#define   KEY1_SHORT_PRESS  1
#define   KEY1_LONG_PRESS   2
#define   KEY2_SHORT_PRESS  4
#define   KEY2_LONG_PRESS   8
#define   NO_KEY            0
#define   KEY_LONG_TIMER    3
void setup() {
  Serial.begin(115200);
  pinMode(led1pin, OUTPUT);
  pinMode(led2pin, OUTPUT);
  pinMode(jdq1pin, OUTPUT);
  pinMode(jdq2pin, OUTPUT);
  pinMode(temup1, INPUT_PULLUP);
  pinMode(temdw1, INPUT_PULLUP);
  pinMode(temup2, INPUT_PULLUP);
  pinMode(temdw2, INPUT_PULLUP);
  pinMode(KEY1, INPUT_PULLUP);
  pinMode(KEY2, INPUT_PULLUP);
    myGizwits.begin();
    //设置LCD要显示的列数、行数,即2行16列
    lcd.begin(16, 2);
    //输出Hello World
    digitalWrite(led1pin, HIGH);
    lcd.print("Smart E-blanket");
    delay(3000);
    lcd.clear();
    digitalWrite(led1pin, LOW);
unsigned long Last_KeyTime = 0;
unsigned long gokit_time_s(void)
  return millis() / 1000;
char gokit_key1down(void)
  unsigned long keep_time = 0;
  if (digitalRead(KEY1) == LOW)
    delay(100);
      keep_time = gokit_time_s();
      while (digitalRead(KEY1) == LOW)
        if ((gokit_time_s() - keep_time) > KEY_LONG_TIMER)
          Last_KeyTime = gokit_time_s();
          return KEY1_LONG_PRESS;
      } //until open the key
      if ((gokit_time_s() - Last_KeyTime) > KEY_LONG_TIMER)
        return KEY1_SHORT_PRESS;
      return 0;
    return 0;
  return 0;
char gokit_key2down(void)
  if (digitalRead(KEY2) == LOW)
    delay(100);
      while (digitalRead(KEY2) == LOW) //until open the key
          return KEY2_LONG_PRESS;
        return KEY2_SHORT_PRESS;
      return 0;
    return 0;
  return 0;
char gokit_keydown(void)
  char ret = 0;
  ret |= gokit_key2down();
  ret |= gokit_key1down();
  return ret;
* KEY_Handle
* @param none
* @return none
void KEY_Handle(void)
  /*  Press for over than 3 second is Long Press  */
  switch (gokit_keydown())
    case KEY1_SHORT_PRESS:
      //lcd.clear();
      lcd.print("Production Test Mode ");
      delay(1000);
      myGizwits.setBindMode(WIFI_PRODUCTION_TEST);
      break;
    case KEY1_LONG_PRESS:
      //lcd.clear();
      lcd.print("Wifi Reset");
      delay(1000);
      myGizwits.setBindMode(WIFI_RESET_MODE);
      break;
    case KEY2_SHORT_PRESS:
     // lcd.clear();
      lcd.print("Soft AP mode");
      delay(1000);
      myGizwits.setBindMode(WIFI_SOFTAP_MODE);
      //Soft AP mode
      break;
    case KEY2_LONG_PRESS:
    //lcd.clear();
    lcd.print("AirLink mode");
    delay(1000);
      myGizwits.setBindMode(WIFI_AIRLINK_MODE);
      //AirLink mode
      break;
    default:
      break;
* Serial Init , Gizwits Init
* @param none
* @return none
  // put your setup code here, to run once:
  //mySerial.println("GoKit init  OK \n");
void wifiStatusHandle()
// if(myGizwits.wifiHasBeenSet(WIFI_SOFTAP))
//   mySerial.println(F("WIFI_SOFTAP!"));
//  if(myGizwits.wifiHasBeenSet(WIFI_AIRLINK))
//    mySerial.println(F("WIFI_AIRLINK!"));
//  if(myGizwits.wifiHasBeenSet(WIFI_STATION))
//    mySerial.println(F("WIFI_STATION!"));
//  if(myGizwits.wifiHasBeenSet(WIFI_CON_ROUTER))
//   mySerial.println(F("WIFI_CON_ROUTER!"));
//  if(myGizwits.wifiHasBeenSet(WIFI_DISCON_ROUTER))
//    mySerial.println(F("WIFI_DISCON_ROUTER!"));
//  if(myGizwits.wifiHasBeenSet(WIFI_CON_M2M))
//    mySerial.println(F("WIFI_CON_M2M!"));
//  if(myGizwits.wifiHasBeenSet(WIFI_DISCON_M2M))
//    mySerial.println(F("WIFI_DISCON_M2M!"));
* Arduino loop
* @param none
* @return none
void loop() {
  //Configure network
  //if(XXX) //Trigger Condition
  //myGizwits.setBindMode(0x02);  //0x01:Enter AP Mode;0x02:Enter Airlink Mode
  /*if ((digitalRead(temup1) == LOW)||(digitalRead(temdw1) == LOW)||(digitalRead(temup2) == LOW)||(digitalRead(temdw2) == LOW))
    delay(1000);
   // digitalWrite(led1pin, LOW);
  sensorValue1 = analogRead(A0);
  sensorValue2 = analogRead(A1);
  float wendu1 = -0.10581*sensorValue1+74.6374;
  float varW_temp1 = wendu1;//Add Sensor Data Collection
  myGizwits.write(VALUE_temp1, varW_temp1);
  lcd.setCursor(0,0);
  lcd.print(wendu1); //获取温度
  //  delay(500);
  lcd.print((char)223); //显示o符号
  lcd.print("C"); //显示字母C
  //delay(500);
  float wendu2 = -0.10581*sensorValue2+74.6374;
  float varW_temp2 = wendu2;//Add Sensor Data Collection
  myGizwits.write(VALUE_temp2, varW_temp2);
  lcd.setCursor(9,0);
  lcd.print(wendu2); //获取温度
  //  delay(500);
  bool varR_power = 0;
    if(myGizwits.hasBeenSet(EVENT_power))
    myGizwits.read(EVENT_power,&varR_power);//Address for storing data
    //mySerial.println(F("EVENT_power"));
    //mySerial.println(varR_power,DEC);
  bool varR_jdq1 = 0;
  if(myGizwits.hasBeenSet(EVENT_jdq1))
    myGizwits.read(EVENT_jdq1,&varR_jdq1);//Address for storing data
    //mySerial.println(F("EVENT_jdq1"));
    //mySerial.println(varR_jdq1,DEC);
  bool varR_jdq2 = 0;
  if(myGizwits.hasBeenSet(EVENT_jdq2))
    myGizwits.read(EVENT_jdq2,&varR_jdq2);//Address for storing data
    //mySerial.println(F("EVENT_jdq2"));
    //mySerial.println(varR_jdq2,DEC);
   KEY_Handle();//key handle , network configure
  wifiStatusHandle();//WIFI Status Handle
  myGizwits.process();
if(myGizwits.hasBeenSet(EVENT_set1))
    myGizwits.read(EVENT_set1,&varR_set1);//Address for storing data
  lcd.setCursor(0,1);
  lcd.print(varR_set1); //获取设置
  //  delay(500);
  //delay(500);
    //mySerial.println(F("EVENT_set1"));
    //mySerial.println(varR_set1,DEC);
  if(wendu1<varR_set1)
    digitalWrite(jdq1pin,HIGH);
if(wendu1>varR_set1+1)
    digitalWrite(jdq1pin, LOW);
  if(myGizwits.hasBeenSet(EVENT_set2))
    myGizwits.read(EVENT_set2,&varR_set2);//Address for storing data
  lcd.setCursor(9,1);
  lcd.print(varR_set2); //获取设置
  //  delay(500);
  //delay(500);
    if(wendu2<varR_set2)
    digitalWrite(jdq2pin,HIGH);
  if(wendu2>varR_set2+1)
    digitalWrite(jdq2pin, LOW);
   /*if ((digitalRead(temup1) == HIGH)||(digitalRead(temdw1) == HIGH)||(digitalRead(temup2) == HIGH)||(digitalRead(temdw2) == HIGH))
    if(temup1 = LOW)
      varR_set1++;
    if(temdw1 = LOW)
      varR_set1--;
    if(temup2 = LOW)
      varR_set2++;
    if(temdw2 = LOW)
      varR_set2--;
   // delay(1000);
   // mySerial.println(F("EVENT_set2"));
   // mySerial.println(varR_set2,DEC);
   //binary datapoint handle
