查看: 1843|回复: 0
[经验] DIY数字仪表:F7开发入门2:数字仪表GUI应用开发
136
管理员
Rank: 9Rank: 9Rank: 9
发表于 2020-1-18 13:02:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TouchGFX MVP通信架构
应用实现按照TouchGFX MVP架构来分层,使得结构清晰:
Backend/ControlF7子板读取G0传感器数据:STM32CubeMX配置USART外设
根据原理图,STM32CubeMX配置G0通过USART2与F7子板通信外设:
串口接收G0子板传感器数据
sensor.cpp
/**  ****************************************************  * @file  * @author  * @version V2.0.0  * @date    07/13/2019  ****************************************************  */#include "sensor.h"#include "usart.h"#include "stdio.h"#include "string.h"extern UART_HandleTypeDef huart4;uint8_t aTxBuffer[30]; //发送缓冲区uint8_t aRxBuffer[1];__IO ITStatus Tx_ready_UART4 = SET; //此处必须赋值SET__IO ITStatus Rx_ready_UART4 = RESET;uint8_t Rx_buff_UART4[30];uint8_t Rx_count_UART4=0; //UART4 接收计数器uint8_t Rx_num_UART4=0; //UART4 一条指令全部接收后的接收字节数extern ts_sensor_data s_sensor_data;//68 01 0E 01 19 01 B4 00 00 00 00 10 5C 6E#define FRM_START                0x68#define FRM_CMD_UPD_SENSOR       0x01#define FRM_FIXLEN               14#define FRM_END0                 0x5c#define FRM_END1                 0x6e#define FRM_POS_START            0#define FRM_POS_CMD              1#define FRM_POS_LEN              2#define FRM_POS_DATA             3#define FRM_POS_CRC              11#define FRM_POS_END0             12#define FRM_POS_END1             13uint8_t cal_crc(uint8_t *buf,uint8_t len){       uint8_t t_crc = 0;       uint8_t r_crc = 0;        //check crc        for(int i=0; i<len ;i++)        {                t_crc += buf;        }        r_crc = (uint8_t)t_crc;        return r_crc;}int8_t parse_sensor_package(void){        uint8_t msg[4];        int rc = 0;        if(Rx_buff_UART4[FRM_POS_START]==FRM_START && Rx_buff_UART4[FRM_POS_CMD]==FRM_CMD_UPD_SENSOR           && Rx_buff_UART4[FRM_POS_CRC] == cal_crc(Rx_buff_UART4,FRM_FIXLEN-3))        {                HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_11);                msg[0]=Rx_buff_UART4[FRM_POS_DATA];                msg[1]=Rx_buff_UART4[FRM_POS_DATA+1];                msg[2]=Rx_buff_UART4[FRM_POS_DATA+2];                msg[3]=Rx_buff_UART4[FRM_POS_DATA+3];                s_sensor_data.temperature[1] = (msg[0]*256+msg[1])/10;                s_sensor_data.temperature[0] = (msg[0]*256+msg[1]);                s_sensor_data.humidity = msg[2]*256+msg[3];        }else{                rc = -1;        }        return rc;}void Start_Next_UART_Receive_IT(UART_HandleTypeDef *UartHandle){        HAL_UART_Receive_IT(UartHandle,aRxBuffer,1); //开启下一次接收中断}void HAL_UART_RxCpltCallback(UART_HandleTypeDef *UartHandle){        uint8_t i=0;        if(UartHandle->Instance == UART4)        {                Rx_buff_UART4[Rx_count_UART4] = aRxBuffer[0];                if(Rx_buff_UART4[Rx_count_UART4-1] == 0x5c && Rx_buff_UART4[Rx_count_UART4] == 0x6e || Rx_count_UART4 > FRM_FIXLEN)//\n                {                        Rx_ready_UART4 = SET;                        Rx_num_UART4 = ++Rx_count_UART4;                        Start_Next_UART_Receive_IT(&huart4); //开启下一次接收中断                }                else                {                        Rx_count_UART4++;                        Start_Next_UART_Receive_IT(&huart4); //开启下一次接收中断                }        }}void sensor_read_init(void){        Start_Next_UART_Receive_IT(&huart4); //开启下一次接收中断}int sensor_read_func(void){        int rc = 0;        if(Rx_ready_UART4==SET)        {                Rx_ready_UART4 = RESET;                rc = parse_sensor_package();                Rx_count_UART4=0;                memset(Rx_buff_UART4,0,sizeof(Rx_buff_UART4));        }else{                rc = -1;        }        return rc;}void sensor_read_start_next(){        Start_Next_UART_Receive_IT(&huart4); //开启下一次接收中断}
传感器读取任务StartsensorTask数据处理
STM32CubeMX配置
Main函数中创建StartsensorTask任务读取将串口收到的数据通过消息队列传给UI的Model层:
ts_sensor_data s_sensor_data;/* USER CODE END Header_StartsensorTask */void StartsensorTask(void const * argument){  /* USER CODE BEGIN StartsensorTask */   sensor_read_init();  /* Infinite loop */    for(;;)    {        if(sensor_read_func()==0)        {                osMessagePut(sensor_msg_qHandle,(uint32_t)&s_sensor_data,200);        }        osDelay(500);    }  /* USER CODE END StartsensorTask */}
Model层通过M->->V更新传感器值
主要代码:Model.cpp
#include <gui/model/Model.hpp>#include <gui/model/ModelListener.hpp>#ifndef SIMULATOR#include "stm32f7xx_hal.h"#include "cmsis_os.h"extern osMessageQId gui_msg_qHandle;extern osMessageQId sensor_msg_qHandle;#endifModel::Model() : modelListener(0){}#define MAX_P_SENSORBOARD_LOST_TIM       300     //static uint16_t s_p_sensorboard_lost_tcnt = 0;void Model::tick(){#ifndef SIMULATOR    osEvent retsensor;    retsensor.value.v = 0;    retsensor = o sMessageGet(sensor_msg_qHandle,1);     ts_sensor_data *p_sensor_data=NULL;    if(retsensor.value.v!=0)    {        p_sensor_data = (ts_sensor_data *)(retsensor.value.v|0x20000000);        modelListener->update_sensor_event(p_sensor_data);        s_p_sensorboard_lost_tcnt = 0;    }        //check if the sensor board disconnected    if(s_p_sensorboard_lost_tcnt++>MAX_P_SENSORBOARD_LOST_TIM)    {         p_sensor_data->humidity=0;         p_sensor_data->temperature[0]=0;p_sensor_data->temperature[1]=0;         modelListener->update_sensor_event(p_sensor_data);          }#endif}
F7子板读取按键数据:
读取任务StartkeyTask数据处理
翻页按键
void StartkeyTask(void const * argument){  /* USER CODE BEGIN StartkeyTask */  /* Infinite loop */  HAL_GPIO_WritePin(KEY5_COM_GPIO_Port, KEY5_COM_Pin,GPIO_PIN_SET);  for(;;)  {        //FY ->NEXT PAGE        if(HAL_GPIO_ReadPin(GPIOA, KEY7_FY_Pin )==GPIO_PIN_SET)        {            osMessagePut(gui_msg_qHandle,0x08,200);            osDelay(1000);        }        osDelay(100);  }  /* USER CODE END StartkeyTask */}
通过Model层通过M->->V更新按键操作
主要代码:
Model.cpp
void Model::tick(){#ifndef SIMULATOR    osEvent retkey;    retkey.value.v = 0;    retkey = osMessageGet(gui_msg_qHandle,1);     if(retkey.value.v==0x08)    {        modelListener->key_event();         }#endif}
Screen1Prensenter.cpp(举例)
void Screen1Presenter::key_event(){    view.handleKeyEvent(8);}
Screen1ViewBase.cpp(举例)
//Handles when a key is pressedvoid Screen1ViewBase::handleKeyEvent(uint8_t key){    if(8 == key)    {        //Interaction1        //When hardware button 8 clicked change screen to Screen2        //Go to Screen2 with screen transition towards East        application().gotoScreen2ScreenSlideTransitionEast();    }}配网按键void StartkeyTask(void const * argument){  /* USER CODE BEGIN StartkeyTask */  /* Infinite loop */  HAL_GPIO_WritePin(KEY5_COM_GPIO_Port, KEY5_COM_Pin,GPIO_PIN_SET);  for(;;)  {        //PW -> WIFI CONF        if(HAL_GPIO_ReadPin(GPIOA, KEY6_PW_Pin )==GPIO_PIN_SET)        {                HAL_GPIO_WritePin(M_CTRL_GPIO_Port, M_CTRL_Pin,GPIO_PIN_SET);                osDelay(200);                HAL_GPIO_WritePin(M_CTRL_GPIO_Port, M_CTRL_Pin,GPIO_PIN_RESET);        }        osDelay(100);  }  /* USER CODE END StartkeyTask */}
UI界面实现资源准备UI界面所需要的图片库
images.7z
TouchGFX设计需要的中文字体
fonts.7z
将解压后的文件,添加到STM32CubeMX生成的Project目录下的C:~\TouchGFX\assets\fonts的fonts文件夹里,然后重新启动TouchGFX。
UI界面制作演示
[backcolor=rgba(255, 255, 255, 0.35)]
00:00 / 47:01
[backcolor=rgba(0, 0, 0, 0.35)]流畅
[backcolor=rgba(0, 0, 0, 0.35)]1x
说明:
1.视频不含有Screen0的配网图标以及Screen5界面的制作(原理是和里面其他的类似)。
2.我们将Screen0的圆环动画的起点设为-40度(视频演示是0度),初始化温度的UI显示为-20度(视频演示是0度)。
3.在这个部分添加红框的内容,UI显示的通配符。
期望实现的界面屏幕切换效果
基本操作步骤1.导入资源
2.TouchGFX designer实现界面Screen0实现
设置与更新传感器值以及按键操作:
void Screen0View::update_sensor_value(ts_sensor_data *p_sensor_data){    Unicode::snprintf(temperTextBuffer1, TEMPERTEXTBUFFER1_SIZE, "%d", p_sensor_data->temperature[1]);    temperText.invalidate();    Unicode::snprintf(temperTextBuffer2, TEMPERTEXTBUFFER1_SIZE, "%d", p_sensor_data->temperature[0]);    temperText.invalidate();    circleProgress1.setValue(p_sensor_data->temperature[1] * 10 + p_sensor_data->temperature[0]);    circleProgress1.invalidate();}void Screen0View::set_sensor_value(ts_sensor_data *p_sensor_data){    v_sensor_data.temperature[0] = p_sensor_data->temperature[0];    v_sensor_data.temperature[1] = p_sensor_data->temperature[1];    v_sensor_data.humidity = p_sensor_data->humidity;}void Screen0View::handleTickEvent(){    wait++;    if (wait>500)    {        ///add test by andy.du 20190710        application().gotoScreen4ScreenSlideTransitionSouth();    }}void Screen0Presenter::key_event(){    view.handleKeyEvent(8);}void Screen0Presenter::update_sensor_event(ts_sensor_data *p_sensor_data){    view.update_sensor_value(p_sensor_data);}Screen1实现
温度仪表盘显示以及按键操作主要代码:
void Screen1View::setupScreen(){    wait = 0;    circleProgress2.setXY(79, 74-10);    circleProgress2.setProgressIndicatorPosition(0, 0, 171, 130);    circleProgress2.setRange(-134, 134);    circleProgress2.setCenter(85, 85);    circleProgress2.setRadius(85-98/2);    circleProgress2.setLineWidth(98);    circleProgress2.setStartEndAngle(-134, 134);    circleProgress2.setCapPrecision(180);      circleProgress2Painter.setBitmap(Bitmap(BITMAP_A001_002_ID));    circleProgress2.setPainter(circleProgress2Painter);    circleProgress2.setValue(z);    image2.setXY(86, 80-10);    image2.setBitmap(Bitmap(BITMAP_A001_004_ID));            textureMapperImage2D.setBitmap(Bitmap(BITMAP_A001_001_ID));    textureMapperImage2D.setWidth(240);    textureMapperImage2D.setHeight(240);    textureMapperImage2D.setXY(0, 0);    textureMapperImage2D.setBitmapPosition(165-3, 80-10);    textureMapperImage2D.setCameraDistance(300.0f);    textureMapperImage2D.setOrigo(165, 92+51+28-20, textureMapperImage2D.getCameraDistance());    textureMapperImage2D.setCamera(textureMapperImage2D.getOrigoX(), textureMapperImage2D.getOrigoY());    textureMapperImage2D.setRenderingAlgorithm(TextureMapper::NEAREST_NEI**OR);    textureMapperImage2D.setVisible(true);             add(textureMapperImage2D);    add(circleProgress2);    add(image2);    textureMapperImage2D.updateZAngle(PI *(-120) / 180.0f);}void Screen1View::handleTickEvent(){    tickCounter++;            if (tickCounter > 100)    {               tickCounter = 0;                Unicode::snprintf(temperTextBuffer1, TEMPERTEXTBUFFER1_SIZE, "%d", From_Presenter_temperature);        Unicode::snprintf(temperTextBuffer2, TEMPERTEXTBUFFER2_SIZE, "%d", From_Presenter_temperature_z);                if(From_Presenter_temperature>=0&&From_Presenter_temperature<10)        {          From_Presenter_temperature=(From_Presenter_temperature-120)+((From_Presenter_temperature-0)*5);        }        else if(From_Presenter_temperature>=10&&From_Presenter_temperature<20)        {          From_Presenter_temperature=(From_Presenter_temperature-70)+((From_Presenter_temperature-10)*5);        }        else if(From_Presenter_temperature>=20&&From_Presenter_temperature<30)        {          From_Presenter_temperature=(From_Presenter_temperature-20)+(((From_Presenter_temperature-20)*5)-2);        }        else if(From_Presenter_temperature>=30&&From_Presenter_temperature<40)        {          From_Presenter_temperature=(From_Presenter_temperature+30)+(((From_Presenter_temperature-30)*5)-2);        }                circleProgress2.setValue(From_Presenter_temperature+From_Presenter_temperature_z-2);            textureMapperImage2D.setupAnimation(AnimationTextureMapper::Z_ROTATION,(PI *(From_Presenter_temperature+From_Presenter_temperature_z-2) / 180.0f),50,0,EasingEquations::expoEaseInOut);        textureMapperImage2D.startAnimation();        circleProgress2.invalidate();        temperText.invalidate();    }}
Screen1View.hpp
void Screen1Presenter::key_event(){    view.handleKeyEvent(8);}void Screen1Presenter::update_sensor_event(ts_sensor_data *p_sensor_data){    view.update_sensor_value(p_sensor_data);}#include "sensor.h"#include <touchgfx/widgets/Image.hpp>#include <touchgfx/widgets/TextureMapper.hpp>#include <touchgfx/widgets/AnimationTextureMapper.hpp>#include <touchgfx/widgets/Box.hpp>#include <touchgfx/widgets/Image.hpp>#include <touchgfx/widgets/TextAreaWithWildcard.hpp>#include <touchgfx/widgets/TextArea.hpp>#include <touchgfx/containers/progress_indicators/CircleProgress.hpp>#include <touchgfx/widgets/canvas/PainterRGB565Bitmap.hpp>#include <touchgfx/widgets/AnimatedImage.hpp>public:virtual void update_sensor_value(ts_sensor_data *p_sensor_data);virtual void handleTickEvent();protected:               const float PI = 3.1415926f;               int tickCounter;               float z;               uint16_t wait;               int From_Presenter_temperature;                uint16_t From_Presenter_temperature_z;                touchgfx::Image image2;                touchgfx::CircleProgress circleProgress2;                touchgfx::AnimationTextureMapper textureMapperImage2D;           // touchgfx::TextureMapper textureMapperImage2D;               touchgfx:ainterRGB565Bitmap circleProgress2Painter;                   private:               static const uint16_t CANVAS_BUFFER_SIZE = 4800;             uint8_t canvasBuffer[CANVAS_BUFFER_SIZE];             ts_sensor_data v_sensor_data;
Screen2实现
温度记录显示以及按键操作主要代码:
void Screen2View::setupScreen(){    wait = 0;    Screen2ViewBase::setupScreen();        CanvasWidgetRenderer::setupBuffer(canvasBuffer, CANVAS_BUFFER_SIZE);    graphT.setXY(40, 0);    graphT.setup(240,200,Color::getColorFrom24BitRGB(255,0,0),Color::getColorFrom24BitRGB(0,0,0));    graphT.set_Draw_Range(0, 240, 200, 0);    graphT.setLineWidth(2);    graphT.setLineVisible(true);    graphT.setAreaVisible(true);    graphT.setDotsVisible(false);    graphT.setDotsBackgroundVisible(false);        graph_Base.setXY(0, 0);    graph_Base.setup(320,240,Color::getColorFrom24BitRGB(176,196,222),Color::getColorFrom24BitRGB(0,0,0));    graph_Base.set_Draw_Range(0, 320, 240, 0);    graph_Base.setLineWidth(1);    graph_Base.setLineVisible(true);    graph_Base.setAreaVisible(false);    graph_Base.setDotsVisible(false);    graph_Base.setDotsBackgroundVisible(false);                graph_avg.setXY(40, 0);    graph_avg.setup(240,200,Color::getColorFrom24BitRGB(176,196,222),Color::getColorFrom24BitRGB(0,0,0));    graph_avg.set_Draw_Range(0, 240, 200, 0);    graph_avg.setLineWidth(1);    graph_avg.setLineVisible(true);    graph_avg.setAreaVisible(false);    graph_avg.setDotsVisible(false);    graph_avg.setDotsBackgroundVisible(false);            add(graphT);    add(graph_Base);    add(graph_avg);        graph_Base.addValue(20,40);    graph_Base.addValue(300,40);        graphT.invalidate();    graph_Base.invalidate();}void Screen2View::handleTickEvent(){    g_tick++;    if(g_tick==30)    {      g_tick=0;      From_Presenter_temperature= v_sensor_data.temperature[1];      From_Presenter_temperature_z=v_sensor_data.temperature[0];      g_y++;             real_temperature=((From_Presenter_temperature+((float)From_Presenter_temperature_z/10))*10)/10;            avg_all=real_temperature;      if (real_temperature >= max_sim)      {          max_sim = real_temperature;          max_w=From_Presenter_temperature;           max_z=From_Presenter_temperature_z;       }             Unicode::snprintf(textArea3Buffer1, 10, "%d", max_w);       Unicode::snprintf(textArea3Buffer2, 10, "%d", max_z);       Unicode::snprintf(textArea3_2Buffer1, 10, "%d", From_Presenter_temperature);       Unicode::snprintf(textArea3_2Buffer2, 10, "%d", From_Presenter_temperature_z);       graphT.addValue(g_y,(From_Presenter_temperature*3));      if(avg_flag>=1)      {         avg=avg_all+avg;         avg_r=avg/avg_flag;          avg_r_w=(uint8_t)avg_r;         avg_r_z=(uint16_t)(avg_r*10)0;                    Unicode::snprintf(textArea3_1Buffer1, 10, "%d", avg_r_w);                 Unicode::snprintf(textArea3_1Buffer2, 10, "%d", avg_r_z);                     graph_avg.clear();         graph_avg.addValue(0,(avg_r_w*3));         graph_avg.addValue(240,(avg_r_w*3));         textArea3_1.invalidate();          graph_avg.invalidate();      }      avg_flag++;        if(avg_flag==240)      {        avg_flag=0;        avg=0;      }      textArea3.invalidate();       textArea3_2.invalidate();       graphT.invalidate();     }    if(g_y==240)    {      g_y=0;      graphT.clear();      time_base_add();    }}void Screen2Presenter::key_event(){    view.handleKeyEvent(8);}void Screen2Presenter::update_sensor_event(ts_sensor_data *p_sensor_data){    //view.update_sensor_value(p_sensor_data);    view.set_sensor_value(p_sensor_data);    }
Screen2View.hpp
#include "Graph.hpp"    virtual void update_sensor_value(ts_sensor_data *p_sensor_data);    virtual void set_sensor_value(ts_sensor_data *p_sensor_data);        virtual void handleTickEvent();    void time_base_add();private:       uint16_t wait;       uint16_t g_tick;       float max_sim;       uint8_t max_z;       uint8_t max_w;       uint16_t From_Presenter_temperature;       uint16_t From_Presenter_temperature_z;       float real_temperature;              Graph graphT;       Graph graph_Base;       Graph graph_avg;              uint8_t Time_base;       uint8_t Time_baseg;       uint8_t Time_baseS;       float avg;       uint16_t avg_flag;       float avg_all;       float avg_r;       uint8_t avg_r_w;       uint8_t avg_r_z;protected:      static const uint16_t CANVAS_BUFFER_SIZE = 4800;      uint8_t canvasBuffer[CANVAS_BUFFER_SIZE];      uint16_t g_y;      ts_sensor_data v_sensor_data;
Screen3实现
湿度记录显示以及按键操作主要代码:
void Screen3View::setupScreen(){    wait = 0;    Screen3ViewBase::setupScreen();        CanvasWidgetRenderer::setupBuffer(canvasBuffer, CANVAS_BUFFER_SIZE);    graphT.setXY(40, 0);    graphT.setup(240,200,Color::getColorFrom24BitRGB(255,0,0),Color::getColorFrom24BitRGB(0,0,0));    graphT.set_Draw_Range(0, 240, 200, 0);    graphT.setLineWidth(2);    graphT.setLineVisible(true);    graphT.setAreaVisible(true);    graphT.setDotsVisible(false);    graphT.setDotsBackgroundVisible(false);        graph_Base.setXY(0, 0);    graph_Base.setup(320,240,Color::getColorFrom24BitRGB(176,196,222),Color::getColorFrom24BitRGB(0,0,0));    graph_Base.set_Draw_Range(0, 320, 240, 0);    graph_Base.setLineWidth(1);    graph_Base.setLineVisible(true);    graph_Base.setAreaVisible(false);    graph_Base.setDotsVisible(false);    graph_Base.setDotsBackgroundVisible(false);    graph_avg.setXY(40, 0);    graph_avg.setup(240,200,Color::getColorFrom24BitRGB(176,196,222),Color::getColorFrom24BitRGB(0,0,0));    graph_avg.set_Draw_Range(0, 240, 200, 0);    graph_avg.setLineWidth(1);    graph_avg.setLineVisible(true);    graph_avg.setAreaVisible(false);    graph_avg.setDotsVisible(false);    graph_avg.setDotsBackgroundVisible(false);            add(graphT);    add(graph_Base);    add(graph_avg);    graph_Base.addValue(20,40);    graph_Base.addValue(300,40);          graphT.invalidate();    graph_Base.invalidate();}void Screen3View::handleTickEvent(){    g_tick++;    if(g_tick==30)    {      g_tick=0;      From_Presenter_humidity= v_sensor_data.humidity;      g_y++;             real_humidity=10000*(From_Presenter_humidity/exp2_16);            avg_all=real_humidity;      if (real_humidity >= max_sim)          max_sim = real_humidity;                Unicode::snprintf(textArea3Buffer, 10, "%d", max_sim);      Unicode::snprintf(textArea3_2Buffer, 10, "%d", real_humidity);             graphT.addValue(g_y,real_humidity);                 if(avg_flag>=1)      {         avg=avg_all+avg;         avg_r=avg/avg_flag;          Unicode::snprintf(textArea3_1Buffer, 10, "%d", avg_r);                        graph_avg.clear();                 graph_avg.addValue(0,avg_r);         graph_avg.addValue(240,avg_r);              textArea3_1.invalidate();          graph_avg.invalidate();      }           avg_flag++;        if(avg_flag==240)      {        avg_flag=0;        avg=0;      }            textArea3.invalidate();       textArea3_2.invalidate();       graphT.invalidate();     }    if(g_y==240)    {      g_y=0;      graphT.clear();      time_base_add();    }}void Screen3Presenter::key_event(){    view.handleKeyEvent(8);}void Screen3Presenter::update_sensor_event(ts_sensor_data *p_sensor_data){    //view.update_sensor_value(p_sensor_data);    view.set_sensor_value(p_sensor_data);    }
Screen3View.hpp
#include "Graph.hpp"    virtual void update_sensor_value(ts_sensor_data *p_sensor_data);      virtual void set_sensor_value(ts_sensor_data *p_sensor_data);         virtual void handleTickEvent();    void time_base_add();private:       uint16_t wait;       uint16_t g_tick;       uint8_t max_sim;       float From_Presenter_humidity;       Graph graphT;       Graph graph_Base;       Graph graph_avg;              uint8_t Time_base;       uint8_t Time_baseg;       uint8_t Time_baseS;       uint16_t avg;       uint16_t avg_flag;       uint16_t avg_all;       uint16_t avg_r;       uint16_t dis_graph_humidity;       uint16_t dis_graph_humidity_av;       uint16_t real_humidity;       uint16_t exp2_16;protected:                        static const uint16_t CANVAS_BUFFER_SIZE = 4800;      uint8_t canvasBuffer[CANVAS_BUFFER_SIZE];      uint16_t g_y;      ts_sensor_data v_sensor_data;Screen4实现
保护界面显示以及按键操作主要代码:
void Screen4View::setupScreen(){    Screen4ViewBase::setupScreen();    CanvasWidgetRenderer::setupBuffer(canvasBuffer, CANVAS_BUFFER_SIZE);    circle1.setPosition(257, 177, 80, 80);    circle1.setCenter(40, 40);    circle1.setRadius(17);    circle1.setLineWidth(2);    circle1.setArc(0, 0);    circle1.setCapPrecision(10);    circle1Painter.setColor(touchgfx::Color::getColorFrom24BitRGB(8, 129, 255));    circle1.setPainter(circle1Painter);    add(circle1);        particleEffect.setPosition(0, 0, HAL:ISPLAY_WIDTH, HAL:ISPLAY_HEIGHT);    particleEffect.setSnapToOrigin(true);    particleEffect.setNumberOfParticles(180);    particleEffect.setOrigin(particleEffect.getWidth() / 2, particleEffect.getHeight() / 2);    particleEffect.setCenter(particleEffect.getWidth() / 2, particleEffect.getHeight() / 2);    // Insert particleEffect jut on top of the background (z-order)    container.insert(&bg_pcb5, particleEffect);    particleEffect.setNumberOfParticles(150);}void Screen4View::handleTickEvent(){    tick++;    itick++;    if(tick==1)    {      tick=0;      if(c_value==360)      {         c_value=0;      }      c_value++;      o_x = rand() % 200 + 20;      o_y=  rand() % 200 + 20;     circle1.setArc(c_value, (c_value+100));     if (itick == 20)     {         itick = 0;         particleEffect.setCenter(o_x, o_y);         particleEffect.invalidate();     }     circle1.invalidate();    }}void Screen4Presenter::key_event(){    view.handleKeyEvent(8);}
Screen4View.hpp
#include <BitmapDatabase.hpp>#include <touchgfx/widgets/AnimationTextureMapper.hpp>#include <touchgfx/widgets/canvas/Circle.hpp>#include <touchgfx/widgets/canvas/PainterRGB565.hpp>#include <stdlib.h>#include <gui/common/ParticleEffect.hpp>               virtual void handleTickEvent();protected:      touchgfx::Circle circle1;      touchgfx:ainterRGB565 circle1Painter;      ParticleEffect particleEffect;      int o_x;      int o_y;      int itick;private:    uint16_t c_value;    uint8_t tick;    AnimationTextureMapper textureMapperImage; Callback<Screen4View, const AnimationTextureMapper&> animationEndedCallback;       void animationEndedHandler(const AnimationTextureMapper& src); void setupAndStartAnimation();     static const uint16_t CANVAS_BUFFER_SIZE = 4800; uint8_t canvasBuffer[CANVAS_BUFFER_SIZE];
Screen5实现
配网界面显示以及操作的主要代码:
Screen5ViewBase.cpp
/******************************************************//******* THIS FILE IS GENERATED BY TOUCHGFX DESIGNER, DO NOT MODIFY ********//******************************************************/#include <gui_generated/screen5_screen/Screen5ViewBase.hpp>#include "BitmapDatabase.hpp"#include <texts/TextKeysAndLanguages.hpp>#include <touchgfx/Color.hpp>Screen5ViewBase::Screen5ViewBase() :    buttonCallback(this, &Screen5ViewBase::buttonCallbackHandler){    bg_320x2401.setXY(0, 0);    bg_320x2401.setBitmap(Bitmap(BITMAP_BG_320X240_ID));    textArea2_1_1.setXY(98, 0);    textArea2_1_1.setColor(touchgfx::Color::getColorFrom24BitRGB(253, 252, 252));    textArea2_1_1.setLinespacing(0);    textArea2_1_1.setTypedText(TypedText(T_SINGLEUSEID123));    wifi_on_off.setXY(98, 56);    wifi_on_off.setBitmap(Bitmap(BITMAP_WIFI_OFF_128_ID));    textArea2.setPosition(0, 215, 320, 25);    textArea2.setColor(touchgfx::Color::getColorFrom24BitRGB(208, 197, 197));    textArea2.setLinespacing(0);    textArea2.setTypedText(TypedText(T_RESOURCEID4));    button1.setXY(278, 92);    button1.setBitmaps(Bitmap(BITMAP_NEXT_BUTTON_ID), Bitmap(BITMAP_NEXT_BUTTON_PRESSED_ID));    button1.setAction(buttonCallback);    add(bg_320x2401);    add(textArea2_1_1);    add(wifi_on_off);    add(textArea2);    add(button1);}void Screen5ViewBase::setupScreen(){}void Screen5ViewBase::buttonCallbackHandler(const touchgfx::AbstractButton& src){    if (&src == &button1)    {        //Interaction1        //When button1 clicked change screen to Screen0        //Go to Screen0 with screen transition towards East        application().gotoScreen0ScreenSlideTransitionEast();    }}
Screen5View.cpp
#include <gui/screen5_screen/Screen5View.hpp>#include "BitmapDatabase.hpp"#include <texts/TextKeysAndLanguages.hpp>Screen5View::Screen5View(){}void Screen5View::setupScreen(){    Screen5ViewBase::setupScreen();}void Screen5View::tearDownScreen(){    Screen5ViewBase::tearDownScreen();}void Screen5View::update_sensor_value(ts_sensor_data *p_sensor_data){    if(p_sensor_data->wifi_status==FRM_CMD_UPD_RESTWIFI)    {        textArea2.setTypedText(TypedText(T_RESOURCEID1));        textArea2.invalidate();    }else if(p_sensor_data->wifi_status==FRM_CMD_UPD_AIRLINK)    {        textArea2.setTypedText(TypedText(T_RESOURCEID2));        textArea2.invalidate();    }else if(p_sensor_data->wifi_status==FRM_CMD_UPD_CONFIGEND)    {        textArea2.setTypedText(TypedText(T_RESOURCEID3));        textArea2.invalidate();    }    else if(p_sensor_data->wifi_status==FRM_CMD_UPD_INITSTAT)    {        textArea2.setTypedText(TypedText(T_RESOURCEID4));        textArea2.invalidate();    }    if(p_sensor_data->wifi_status==FRM_CMD_UPD_CONFIGEND)    {        wifi_on_off.setBitmap(Bitmap(BITMAP_WIFI_ON_128_ID));        wifi_on_off.invalidate();    }else{        wifi_on_off.setBitmap(Bitmap(BITMAP_WIFI_OFF_128_ID));        wifi_on_off.invalidate();    }}
