查看: 16154|回复: 3
[资料] Connectyin with AWS Lambda pls help
 楼主| 发表于 2020-9-18 12:47:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Hi All
Thank you for reading. I am trying to integrate gizwits with AWS lambda. What is the best approach to do this?
Basically I want the product messages routed to AWS lambda from where I can do the needed code to
Please help
136
管理员
Rank: 9Rank: 9Rank: 9
发表于 2020-9-22 17:39:46 | 只看该作者
FYI
http://docs.gizwits.com/en-us/UserManual/EchoIntegration.html
If you need more help feel free to let me know.  Thanks
Thank you Sir for the reply. I understand from the doc that we need to use open API.. This is what I am trying to achieve 1)We will have a fleet of devices that will send water flow information to giz  详情 回复 发表于 2020-9-28 11:51
 楼主| 发表于 2020-9-28 11:51:28 | 只看该作者
admin 发表于 2020-9-22 17:39
FYI
1)We will have a fleet of devices that will send water flow information to gizwits
2)AWS Lambda will connect to gizwits via open api and get this information on a schedule every hour
Is this approach feasible? If so how to proceed??
Appreciate your help
Thanks
Subin
Yes, I think it is feasible. 1. You can follow the basic steps to make your devices connect to Gizwits http://docs.gizwits.com/en-us/quickstart/GizwitsQuickStart.html 2. It is recommended to use SNo  详情 回复 发表于 2020-9-28 14:42
136
管理员
发表于 2020-9-28 14:42:34 | 只看该作者
This is what ...
2. It is recommended to use SNoti API to set up the communication between AWS and Gizwits
http://docs.gizwits.com/en-us/cloud/NotificationAPI.html
