查看: 9397|回复: 3
[技术问答] esp8266-01现在无法soc使用机智云了吗?
 楼主| 发表于 2021-6-22 14:59:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
---UPGRADE_FW_BIN1---
[030392][Local] default szWechatDeviceType    : gh_35dd1e10ab57
[030392][Local] default szGAgentSoftApName    : XPG-GAgent-c8ae
[030392][Local] default szGAgentSoftApPwd     : 123456789
[030392][Local] default szGAgentSever         : api.gizwits.com
[030392][Local] default gagentSeverPort       : 80
[030392][Local] default localHBIntervalS      : 40
[030392][Local] default localTransIntervalMS  : 450
[030392][Local] default m2mKeepAliveS         : 150
[030392][Local] default m2mHBIntervalS        : 50
[030392][Local] default timeZoneS             : 0
[030392][Local] default configMode            : 2
[030392][Local] default tScanNum              : 0
[030392][Local] default tCon                  : 0
[026792][Dev] GAgent_DevGetConfigData Flash data Error.
[026792][Dev]  Magic number different : 0.[026792][Local] GAgent creat new passcode : PNE***KXG
[026792][Dev]  Save gagent config data,start erase flash.
[026792][Dev]  Flash erase failed, err: 1
[025760][Log] gatLogGetBufOffset finding header error...
[025760][Log] gatLogErrorProess :has error data,erase flash!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.
[025760][Log] gagentLogInit wOffset:0 rOffset:0.
[025760][Dev] Domain:api.gizwits.com:80.
[025760][Dev] tz in sec:28800,timezone:8.0
[025696][LanOTA] lanOTAInit ...... ok
[025648][Simulator] GAgent lib Time:Jan 15 2021 12:40:23
[025648][GAgent] GAgent Start...
[025648][WiFiEvent] GAgent_WiFiInit preSetWifiMode:1 expectWifiMode:2.
[025648][NWK] NWK_WIFI_ONBOARDING_UP
SC version: V2.5.4
[025384][WiFiEvent] OpenAirlink...
[025384][Local] MCU old product_key: need to Refresh
[025384][Local] GAgent creat new passcode : KFC***WCC
[025384][Dev]  Save gagent config data,start erase flash.
[025384][Dev]  Flash erase failed, err: 1
[025384][Local] ----------------------------------------- GAGENT INFO --------------------------------------
[025384][Local] GAgent Work in GAGENT_SOC.
[025384][Local] GAgent Product Soft Version:04020A25.
[025384][Local] GAgent Product Hard Version:00ESP826.
[025384][Local] GAgent Compiled Time       :Jan 15 2021, 12:40:24.
[025384][Local] GAgent cache first ssid    :.
[025384][Local] GAgent backup ssid         :.
[025384][Local] GAgent mac                 :84f3eb90c8ae
[025384][025384][Auth] No authkey in this flash,need to create.
[025384][Auth] auth key create success.
[Local] GAgent authKey             :a54******************a42
[025384][Local] GAgent passcodelen:10      :KFC***WCC
[025384][Local] GAgent did                 :
[025384][Local] GAgent old passcode        NE***KXG
[025384][Local] GAgent old_did             :
[025384][Local] GAgent old pk              :eeb85cfd2435462d970d99d22f12ae9c len:32
[025384][Local] GAgent AP name             :XPG-GAgent-c8ae
[025384][Local] GAgent 3rd cloud           :
[025384][Local] GAgent M2M Host            : , IP :0.0.0.0
[025384][Local] GAgent Default GServer Host:api.gizwits.com port:80
[025384][Local] GAgent GService Host       : , Port :0 , IP :0.0.0.0
[025384][Local] GAgent BizLogLev           :00,SysLogLev:00
[025384][Local] GAgent tz_offset           :28800
[025384][Local] GAgent location_id         :0
[025384][Local] GAgent MCU Protocol Vertion:00000004.
[025384][Local] GAgent MCU P0 Vertion      :00000002.
[025384][Local] GAgent MCU Hard Vertion    :03000001.
[025384][Local] GAgent MCU Soft Vertion    :03030000.
[025384][Local] GAgent WeChat Device Type:gh_******b57
[025384][Local] Flash Size:FLASH_SIZE_32Mbit .
[025384][Local] --------------------------------------------------------------------------------------
devAuthResultCb
gizwitsInit OK
gpio_name 0
--- system_free_size = 25360 ---
mode : sta(84:f3:eb:90:c8:ae)
add if0
scandone
[023800][NWK] gagentNwkEventCB event: 0x0040
[023800][Local] GAgentStatus change, lastGAgentStatus:0x0000, newGAgentStatus:0x000C
@@@@ GAgentStatus[hex]:0c | [Bin]:0,0,1,1,0,0
OnBoarding: AirLink mode
WiFi status: in binding mode
@@@@ RSSI 0
[023800][FR]  Cancle router connect monitor.
[023800][Dev]  Save gagent config data,start erase flash.
[023800][Dev]  Flash erase failed, err: 1
[023800][NWK] haiNwkStatus: 0x000C, gagentStatus: 0x000C
[14:54:53.520]收←◆scandone
[14:54:55.647]收←◆scandone
[021968][WiFiEvent] SC_STATUS_FIND_CHANNEL
 楼主| 发表于 2021-6-22 15:04:00 | 只看该作者
如果所示,下载的8M源码,像往常一编译,但2019年下载下来的编译没问题,今天刚下的编译后还是显示32M,wifi数据  写入flash错误。[023800][Dev]  Flash erase failed, err: 1
发表于 2021-6-25 15:52:54 | 只看该作者
可以正常使用了
发表于 2021-8-24 18:02:38 | 只看该作者
我也是这个问题
