查看: 40916|回复: 16
亲测WS2812 RGB彩灯MCU和SOC方案实现
20
发表于 2017-4-6 09:30:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
      市场上RGB的LED灯很多。控制方式也很多,如PWM的。I2C的。现在介绍一款只需一个GPIO就能控制的内置WS2812的5050灯珠
市场价格在0.4元左右一个。
实现方式论坛里也有介绍。这里介绍亲测的两种方式
第一种MCU方案 基于STM32F103C8T6
第二种 SOC 方案 基于 esp8266
WS2812B.c
#include  "Hal_WS2812B/WS2812B.h"
#include "stm32f10x_dma.h"
#include "stm32f10x.h"
#include "stm32f10x_tim.h"
#include "stdio.h"
/* Buffer that holds one complete DMA transmission
* Ensure that this buffer is big enough to hold
* all data bytes that need to be sent
* The buffer size can be calculated as follows:
* number of LEDs * 24 bytes + 42 bytes
* This leaves us with a maximum string length of
* (2^16 bytes per DMA stream - 42 bytes)/24 bytes per LED = 2728 LEDs
#define TIM3_CCR3_Address 0x4000043c         // physical memory address of Timer 3 CCR1 register
//#define TIM3_CCR1_Address 0x40000434        // physical memory address of Timer 3 CCR1 register
#define TIMING_ONE  50
#define TIMING_ZERO 25
uint16_t LED_BYTE_Buffer[300];
void Timer3_init(void)
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  GPIO_InitTypeDef GPIO_InitStructure;
  DMA_InitTypeDef DMA_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
        /* GPIOA Configuration: TIM3 Channel 1 as alternate function push-pull */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
        /* Compute the prescaler value */
        //PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
        /* Time base configuration */
        TIM_TimeBaseStructure.TIM_Period = 90-1; // 800kHz
        TIM_TimeBaseStructure.TIM_Prescaler = 0;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
        /* PWM1 Mode configuration: Channel1 */
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_Pulse = 0;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
        TIM_OC3Init(TIM3, &TIM_OCInitStructure);
        /* configure DMA */
        /* DMA clock enable */
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
        /* DMA1 Channel6 Config */
        DMA_DeInit(DMA1_Channel3);
        DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)TIM3_CCR3_Address;        // physical address of Timer 3 CCR1
        DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)LED_BYTE_Buffer;                // this is the buffer memory
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;                                                // data shifted from memory to peripheral
        DMA_InitStructure.DMA_BufferSize = 42;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                                        // automatically increase buffer index
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;                                                        // stop DMA feed after buffer size is reached
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
        DMA_Init(DMA1_Channel3, &DMA_InitStructure);
                /* TIM3 CC1 DMA Request enable */
        TIM_DMACmd(TIM3, TIM_DMA_Update, ENABLE);
/* This function sends data bytes out to a string of WS2812s
* The first argument is a pointer to the first RGB triplet to be sent
* The seconds argument is the number of LEDs in the chain
* This will result in the RGB triplet passed by argument 1 being sent to
* the LED that is the furthest away from the controller (the point where
* data is injected into the chain)
/ *此函数将数据字节发送到WS2812的字符串
*第一个参数是指向要发送的第一个RGB三元组的指针
* seconds参数是链中的LED数量
*这将导致通过参数1传递的RGB三元组发送到
*离控制器最远的LED(
*数据被注入链中
void WS2812_send(uint8_t (*color)[3], uint16_t len)
        uint8_t i;
        uint16_t memaddr;
        uint16_t buffersize;
        buffersize = (len*24)+43;        // number of bytes needed is #LEDs * 24 bytes + 42 trailing bytes
        memaddr = 0;                                // reset buffer memory index
        while (len)
                                for(i=0; i<8; i++) // GREEN data
                                        LED_BYTE_Buffer[memaddr] = ((color[0][1]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
                                        memaddr++;
                        for(i=0; i<8; i++) // RED
                                        LED_BYTE_Buffer[memaddr] = ((color[0][0]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
                                        memaddr++;
                        for(i=0; i<8; i++) // BLUE
                                        LED_BYTE_Buffer[memaddr] = ((color[0][2]<<i) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
                                        memaddr++;
                  len--;
//bug:最后一个周期波形不知道为什么全是高电平,故增加一个波形
          LED_BYTE_Buffer[memaddr] = ((color[0][2]<<8) & 0x0080) ? TIMING_ONE:TIMING_ZERO;
          memaddr++;
                while(memaddr < buffersize)
                        LED_BYTE_Buffer[memaddr] = 0;
                        memaddr++;
                DMA_SetCurrDataCounter(DMA1_Channel3, buffersize);         // load number of bytes to be transferred
                DMA_Cmd(DMA1_Channel3, ENABLE);                         // enable DMA channel 6
                TIM_Cmd(TIM3, ENABLE);                                                 // enable Timer 3
                while(!DMA_GetFlagStatus(DMA1_FLAG_TC3)) ;         // wait until transfer complete
                TIM_Cmd(TIM3, DISABLE);         // disable Timer 3
                DMA_Cmd(DMA1_Channel3, DISABLE);                         // disable DMA channel 6
                DMA_ClearFlag(DMA1_FLAG_TC3);                                 // clear DMA1 Channel 6 transfer complete flag
WS2812B.H
#ifndef __WS2812B_H
#define        __WS2812B_H
#include "delay.h"
void Timer3_init(void);
void WS2812_send(uint8_t (*color)[3], uint16_t len);
#endif /* __LED_H */
27
推荐
发表于 2017-5-5 23:02:57 | 只看该作者
jipin 发表于 2017-5-5 08:34
试下修改颜色之前 设置一次黑色。
在user_main.c中的init事件中,调用的ws2812的init初始化函数。
但接电模块启动后,还总是总是亮个绿灯。
20
 楼主| 发表于 2017-4-6 09:34:32 | 只看该作者
续。。。
ws2812.c
#include "driver/ws2812.h"
#include "ets_sys.h"
#include "user_interface.h"
#include "osapi.h"
//#define GPIO_OUTPUT_SET(gpio_no, bit_value) gpio_output_set(bit_value<<gpio_no, ((~bit_value)&0x01)<<gpio_no, 1<<gpio_no,0)
void ICACHE_FLASH_ATTR SEND_WS_0()//关
       uint8_t time;
       time = 4; while(time--) WRITE_PERI_REG( PERIPHS_GPIO_BASEADDR + GPIO_ID_PIN(WSGPIO), 1 );
       time = 7; while(time--) WRITE_PERI_REG( PERIPHS_GPIO_BASEADDR + GPIO_ID_PIN(WSGPIO), 0 );
void ICACHE_FLASH_ATTR SEND_WS_1()//开
       uint8_t time;
       time = 10; while(time--) WRITE_PERI_REG( PERIPHS_GPIO_BASEADDR + GPIO_ID_PIN(WSGPIO), 1 );
       time = 2; while(time--) WRITE_PERI_REG( PERIPHS_GPIO_BASEADDR + GPIO_ID_PIN(WSGPIO), 0 );
void ICACHE_FLASH_ATTR ws2812_strip(uint8_t R,uint8_t G,uint8_t B, uint16_t length)
        uint16_t i=0;
        uint16_t j=0;
        uint8_t byte;
        uint8_t mask=0x80;
        uint8_t buff[600];
        uint16_t length2=(length*3);
       GPIO_OUTPUT_SET(GPIO_ID_PIN(WSGPIO), 0);
       system_soft_wdt_stop();
       ets_intr_lock();
       while(length2--)
              mask = 0x80;
              switch(i)
                     case 0:byte=G; i++;
                     break;
                     case 1:byte=R; i++;
                     break;
                     case 2:byte=B; i=0;
                     break;
              while (mask)
                    ( byte & mask ) ? (buff[j++]=1) : (buff[j++]=0);
                     mask >>= 1;
              i=0;
              while (i<= j)
                    ( buff[i++] & 0x01) ? SEND_WS_1() : SEND_WS_0();
              // while (mask)
              //       ( byte & mask ) ? SEND_WS_1() : SEND_WS_0();
              //        mask >>= 1;
       ets_intr_unlock();
       system_soft_wdt_restart();
void ICACHE_FLASH_ATTR ws2812_init()
  //PIN_PULLUP_EN(PERIPHS_IO_MUX_GPIO0_U);
  //PIN_PULLUP_DIS(PERIPHS_IO_MUX_GPIO0_U);
  //GPIO_OUTPUT_SET(GPIO_ID_PIN(WSGPIO), 0);
       ws2812_strip(0,0,0, LEDS);
ws2812.h
#ifndef _WS2812_H
#define _WS2812_H
#include "c_types.h"
#include "gpio.h"
#define WSGPIO 0 //只能是GPIO0,其它端口无用,不解
#define LEDS 21 //LED数量
void ICACHE_FLASH_ATTR ws2812_strip(uint8_t R,uint8_t G,uint8_t B, uint16_t length);
void  ws2812_init();
#endif
楼主我有些细节问题想请教,能加个qq联系吗?  详情 回复 发表于 2017-4-7 16:21
9
发表于 2017-4-7 16:12:41 | 只看该作者
6666666666666666666
发表于 2017-4-7 16:21:19 | 只看该作者
jipin 发表于 2017-4-6 09:34
续。。。
ws2812.c
20
 楼主| 发表于 2017-4-7 17:19:40 | 只看该作者
49707555
49707555
27
发表于 2017-4-9 23:46:08 | 只看该作者
您好,关于SOC方案调用ws2812,有例程吗?
我直接试了。在初始化以后,一直是绿灯,开灯和关灯,都没有效果,改变颜色与没有成功。
方便的话,是否能提供个使用的demo,估计是我使用的不对。
我是直接找了个esp8266的空工程添加的这2个文件,测试的。
已解决,见10楼。
直接按soc方案的烧写设置就成
20
 楼主| 发表于 2017-4-11 10:10:17 | 只看该作者
这个不难理解。自己找下原因、
发表于 2017-4-11 16:53:47 | 只看该作者
这个不错啊,回头自己可以diy一个wifi控制的彩灯了,谢谢分享啊
发表于 2017-4-12 16:04:26 | 只看该作者
不错,学习了!!
27
发表于 2017-4-13 20:53:33 | 只看该作者
哪位兄台也玩过这个,可否给个调用的例子学习下。
一直尝试了几天,到目前也没有成功
20
 楼主| 发表于 2017-4-14 22:54:51 | 只看该作者
一直尝试了几天,到目前也没有成功 ...
看下代码就行了
27
12#
发表于 2017-5-2 17:16:05 | 只看该作者
不知是个人原因,还是通病,代码稍修改后,可以正常使用了。1复制ws2812.c文件到app\driver目录
2复制ws2812.h文件到app\include\driver目录
3在UserMain.c中的user_init()函数中添加初始化代码:
ws2812_init();
4具体颜色调用
ws2812_strip(255,0,0, LEDS);//绿色
gizMSleep(); //延时
ws2812_strip(0,255,0, LEDS);//红色
gizMSleep();
ws2812_strip(0,0,255, LEDS);//蓝色
gizMSleep();
ws2812_strip(255,255,255, LEDS);//白色
gizMSleep();
ws2812_strip(0,0,0, LEDS);//关灯
ws2812_soc驱动.rar (1.36 KB, 下载次数: 145)
另外,就在刚刚,又看到了大牛发的新库,一会去试试。
http://club.gizwits.com/thread-6116-1-1.html?tn=96100419_hao_pg
27
13#
发表于 2017-5-3 20:36:12 | 只看该作者
其他朋友,有没有遇到初始化以后,总是亮着一个绿灯。
然后在调色时,有时候也会出一个灯颜色不正常。
有时全部关闭后,还是亮一个绿灯的情况?
我这测试了12颗灯的灯板。有这样的情况。
20
14#
 楼主| 发表于 2017-5-5 08:34:42 | 只看该作者
有时 ...
试下修改颜色之前 设置一次黑色。
16#
发表于 2017-9-16 08:51:18 | 只看该作者
这个方案有原理图可以提供吗
17#
发表于 2020-1-9 14:13:56 | 只看该作者
这个很赞啊 成品方案智能灯我最近也准备弄一个 ~
