查看: 8760|回复: 0
Linux Socker errno
56
发表于 2017-10-17 17:54:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
经常有同事问我,socket 错误之后打印的错误码是什么意思,每次都要解释,所以,索性整理一下,供大家查看
errno 是记录系统的最后一次错误代码。代码是一个int型的值,在errno.h中定义
注意:只有当一个库函数失败时,errno才会被设置。当函数成功运行时,errno的值不会被修改。这意味着我们不能通过测试errno的值来判断是否有错误存在。反之,只有当被调用的函数提示有错误发生时检查errno的值才有意义。
错误数
描述
errno0
Success
errno1
Operation not permitted
errno2
No such file or directory
errno3
No such process
errno4
Interrupted system call
errno5
Input/output error
errno6
No such device or address
errno7
Argument list too long
errno8
Exec format error
errno9
Bad file descriptor
errno10
No child processe
errno11
Resource temporarily unavailable
errno12
Cannot allocate memory
errno13
Permission denied
errno14
Bad address
errno15
Block device required
errno16
Device or resource busy
errno17
File exists
errno18
Invalid cross-device link
errno19
No such device
errno20
Not a directory
errno21
Is a directory
errno22
Invalid argument
errno23
Too many open files in system
errno24
Too many open files
errno25
Inappropriate ioctl for device
errno26
Text file busy
errno27
File too large
errno28
No space left on device
errno29
Illegal seek
errno30
Read-only file system
errno31
Too many links
errno32
Broken pipe
errno33
Numerical argument out of domain
errno34
Numerical result out of range
errno35
Resource deadlock avoided
errno36
File name too long
errno37
No locks available
errno38
Function not implemented
errno39
Directory not empty
errno40
Too many levels of symbolic links
errno41
Unknown error 41
errno42
No message of desired type
errno43
Identifier removed
errno44
Channel number out of range
errno45
Level 2 not synchronized
errno46
Level 3 halted
errno47
Level 3 reset
errno48
Link number out of range
errno49
Protocol driver not attached
errno50
No CSI structure available
errno51
Level 2 halted
errno52
Invalid exchange
errno53
Invalid request descriptor
errno54
Exchange full
errno55
No anode
errno56
Invalid request code
errno57
Invalid slot
errno58
Unknown error 58
errno59
Bad font file format
errno60
Device not a stream
errno61
No data available
errno62
Timer expired
errno63
Out of streams resources
errno64
Machine is not on the network
errno65
Package not installed
errno66
Object is remote
errno67
Link has been severed
errno68
Advertise error
errno69
Srmount error
errno70
Communication error on send
errno71
Protocol error
errno72
Multihop attempted
errno73
RFS specific error
errno74
Bad message
errno75
Value too large for defined datatype
errno76
Name not unique on network
errno77
File descriptor in bad state
errno78
Remote address changed
errno79
Can not access a needed sharedlibrary
errno80
Accessing a corrupted sharedlibrary
errno81
.lib section in a.out corrupted
errno82
Attempting to link in too manyshared libraries
errno83
Cannot exec a shared librarydirectly
errno84
Invalid or incomplete multibyte orwide character
errno85
Interrupted system call should berestarted
errno86
Streams pipe error
errno87
Too many users
errno88
Socket operation on non-socket
errno89
Destinationaddress required
errno90
Message too long
errno91
Protocol wrong type for socket
errno92
Protocol not available
errno93
Protocol not supported
errno94
Socket type not supported
errno95
Operation not supported
errno96
Protocol family not supported
errno97
Address family not supported byprotocol
errno98
Address already in use
errno99
Cannot assign requested address
errno100
Network is down
errno101
Network is unreachable
errno102
Network dropped connection onreset
errno103
Software caused connection abort
errno104
Connection reset by peer
errno105
No buffer space available
errno106
Transport endpoint is alreadyconnected
errno107
Transport endpoint is notconnected
errno108
Cannot send after transportendpoint shutdown
errno109
Too many references: cannot splice
errno110
Connection timed out
errno111
Connection refused
errno112
Host is down
errno113
No route to host
errno114
Operation already in progress
errno115
Operation now in progress
errno116
Stale NFS file handle
errno117
Structure needs cleaning
errno118
Not a XENIX named type file
errno119
No XENIX semaphores available
errno120
Is a named type file
errno121
Remote I/O error
errno122
Disk quota exceeded
errno123
No medium found
errno124
Wrong medium type
errno125
Operation canceled
errno126
Required key not available
errno127
Key has expired
errno128
Key has been revoked
errno129
Key was rejected by service
errno130
Owner died
errno131
State not recoverable
errno132
Operation not possible due toRF-kill
errno133
Unknown error 133
errno134
Unknown error 134
errno135
Unknown error 135
errno136
Unknown error 136
errno137
Unknown error 137
errno138
Unknown error 138
errno139
Unknown error 139
