查看: 9911|回复: 2
[问答] Linux编译机智云自动生成的SOC代码,烧录后,工作异常
发表于 2018-6-24 07:22:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
使用机智云自动生成的SOC进行编译,
gen_misc.sh文件内容:
boot=new
echo "boot mode: $boot"
app=1
echo "app:$app"
spi_speed=40
echo "spi speed: $spi_speed MHz"
spi_mode=QIO
echo "spi mode: $spi_mode"
spi_size_map=6
echo "spi_size_map:$spi_size_map"
make COMPILE=gcc BOOT=$boot APP=$app SPI_SPEED=$spi_speed SPI_MODE=$spi_mode SPI_SIZE_MAP=$spi_size_map
编译结果:
root@ubuntu:/mnt/hgfs/ESP/GizwitsSoCesp8266_32M2018062313112387720f66e4/SoC_ESP8266_32M_source/app# ./gen_misc.sh
gen_misc.sh version 20150511
boot mode: new
app:1
spi speed: 40 MHz
spi mode: QIO
spi_size_map:6
make[1]: Entering directory '/mnt/hgfs/ESP/GizwitsSoCESP8266_32M2018062313112387720f66e4/SoC_ESP8266_32M_source/app/user'
make[1]: Leaving directory '/mnt/hgfs/ESP/GizwitsSoCESP8266_32M2018062313112387720f66e4/SoC_ESP8266_32M_source/app/user'
make[1]: Entering directory '/mnt/hgfs/ESP/GizwitsSoCESP8266_32M2018062313112387720f66e4/SoC_ESP8266_32M_source/app/driver'
make[1]: Leaving directory '/mnt/hgfs/ESP/GizwitsSoCESP8266_32M2018062313112387720f66e4/SoC_ESP8266_32M_source/app/driver'
make[1]: Entering directory '/mnt/hgfs/ESP/GizwitsSoCESP8266_32M2018062313112387720f66e4/SoC_ESP8266_32M_source/app/Gizwits'
make[1]: Leaving directory '/mnt/hgfs/ESP/GizwitsSoCESP8266_32M2018062313112387720f66e4/SoC_ESP8266_32M_source/app/Gizwits'
make[1]: Entering directory '/mnt/hgfs/ESP/GizwitsSoCESP8266_32M2018062313112387720f66e4/SoC_ESP8266_32M_source/app/Utils'
make[1]: Leaving directory '/mnt/hgfs/ESP/GizwitsSoCESP8266_32M2018062313112387720f66e4/SoC_ESP8266_32M_source/app/Utils'
mkdir -p ../bin/upgrade
1681824114
1681824115
Support boot_v1.4 and +
Generate user1.4096.new.6.bin successully in folder bin/upgrade.
boot.bin------------>0x00000
user1.4096.new.6.bin--->0x01000
root@ubuntu:/mnt/hgfs/ESP/GizwitsSoCESP8266_32M2018062313112387720f66e4/SoC_ESP8266_32M_source/app#
程序烧录设置:
串口每次打印信息:
ets Jan  8 2013,rst cause:2, boot mode:(3,6)
tail 8
chksum 0xe5
tail 8
chksum 0x84
tail 8
chksum 0xd8
csum 0xd8
2nd boot version : 1.6
  SPI Speed      : 40MHz
  SPI Mode       : QIO
  SPI Flash Size & Map: 32Mbit(1024KB+1024KB)
jump to run user1 @ 1000
rf cal sector: 636
rf[112] : 00
rf[113??
然后就停止打印了,可是程序还在运行,KEY1和KEY2按键都可以起作用的,但是没有相应的打印信息,并且DEV和APP直接信息交互是正常的,但是DEV实际无法控制GPIO!
请问这是什么原因?
 楼主| 发表于 2018-6-24 08:35:19 | 只看该作者
#结贴#那是用串口1打印的!也就是GPIO2脚!
发表于 2018-12-10 16:07:32 | 只看该作者
对,把串口号改成0:
UART_SetPrintPort(0);
