查看: 11165|回复: 0
[问答] 哪位大神能帮忙看看为什么GoKit3温湿度为什么读不出来数...
发表于 2018-7-11 23:09:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
void userInit(void)
    memset((uint8_t*)¤tDataPoint, 0, sizeof(dataPoint_t));
   //delayInit(72);
      rgbLedInit();      //RGB LED管脚初始化
   rgbKeyGpioInit();  //
   dht11Init();       //温湿度初始化
    /** Warning !!! DataPoint Variables Init , Must Within The Data Range **/
      currentDataPoint.valueLED_OnOff = ;
      currentDataPoint.valueLED_Color = ;
      currentDataPoint.valueLED_R = ;
      currentDataPoint.valueLED_G = ;
      currentDataPoint.valueLED_B = ;
      currentDataPoint.valueMotor_Speed = ;
      currentDataPoint.valueInfrared = ;*/
      //currentDataPoint.valueTemperature =20;
     // currentDataPoint.valueHumidity =25;
      /*currentDataPoint.valueAlert_1 = ;
      currentDataPoint.valueAlert_2 = ;
      currentDataPoint.valueFault_LED = ;
      currentDataPoint.valueFault_Motor = ;
      currentDataPoint.valueFault_TemHum = ;
#include <main.h>
#include "bsp_temp_hum.h"
thTypedef_t temphumTypedef;
//Reset DHT11
static void dht11Rst(void)
    DHT11_IO_OUT();                //SET OUTPUT
    DHT11_DQ_OUT=0;                //GPIOA.0=0
    Delay_ms(20);                   //Pull down Least 18ms
    DHT11_DQ_OUT=1;                //GPIOA.0=1
    Delay_us(30);                    //Pull up 20~40us
static uint8_t dht11Check(void)
    uint8_t retry=0;
    DHT11_IO_IN();                                              //SET INPUT
    while (DHT11_DQ_IN && (retry<100))                          //DHT11 Pull down 40~80us
        retry++;
        Delay_us(1);
    if(retry >= 100)
        return 1;
    else
        retry=0;
    while (!DHT11_DQ_IN&& (retry < 100))      //DHT11 Pull up 40~80us
        retry++;
        Delay_us(1);
    if(retry >= 100)
        return 1;                         //check error
    return 0;
static uint8_t dht11ReadBit(void)
    uint8_t retry=0;
    while(DHT11_DQ_IN && (retry<100))                           //wait become Low level
        retry++;
        Delay_us(1);
    retry = 0;
    while(!DHT11_DQ_IN && (retry < 100))      //wait become High level
        retry++;
        Delay_us(1);
    Delay_us(30);//wait 40us
    if(DHT11_DQ_IN)
        return 1;
    else
        return 0;
static uint8_t dht11ReadByte(void)
    uint8_t i,dat;
    dat=0;
    for (i=0; i<8; i++)
        dat<<=1;
        dat |= dht11ReadBit();
    return dat;
static uint8_t dht11ReadData(uint8_t *temperature, uint8_t *humidity)
    uint8_t buf[5];
    uint8_t i;
    dht11Rst();
    if(0 == dht11Check())
    //USART1_printf("curTem=%d curHum=%d \r\n",curTem,curHum);
      USART1_printf("Programm is here\r\n");
        for(i=0; i<5; i++)
            buf = dht11ReadByte();
        if(buf[4] == (buf[0]+buf[1]+buf[2]+buf[3]))
            *humidity = buf[0];
            *temperature = buf[2];
    else
        return 1;
    return 0;
uint8_t dht11Read(uint8_t *temperature, uint8_t *humidity)
    uint8_t curTem = 0, curHum = 0;
    uint16_t temMeans = 0, humMeans = 0;
    uint8_t curI = 0;
    uint8_t ret = 0;
    ret = dht11ReadData(&curTem, &curHum);
    if(1 != ret)
        //Cycle store ten times stronghold
        if(MEAN_NUM > temphumTypedef.curI)
            temphumTypedef.thBufs[temphumTypedef.curI][0] = curTem;
            temphumTypedef.thBufs[temphumTypedef.curI][1] = curHum;
            temphumTypedef.curI++;
        else
            temphumTypedef.curI = 0;
    else
        return (1);
    if(MEAN_NUM <= temphumTypedef.curI)
        temphumTypedef.thAmount = MEAN_NUM;
    if(0 == temphumTypedef.thAmount)
        //Calculate Before ten the mean
        for(curI = 0; curI < temphumTypedef.curI; curI++)
            temMeans += temphumTypedef.thBufs[curI][0];
            humMeans += temphumTypedef.thBufs[curI][1];
        temMeans = temMeans / temphumTypedef.curI;
        humMeans = humMeans / temphumTypedef.curI;
        *temperature = temMeans;
        *humidity    = humMeans;
    else if(MEAN_NUM == temphumTypedef.thAmount)
        //Calculate After ten times the mean
        for(curI = 0; curI < temphumTypedef.thAmount; curI++)
        temMeans = temMeans / temphumTypedef.thAmount;
        humMeans = humMeans / temphumTypedef.thAmount;
        *temperature = (uint8_t)temMeans;
        *humidity    = (uint8_t)humMeans;
    return (0);
uint8_t dht11Init(void)
    /* Migrate your driver code */
    GPIO_InitTypeDef  GPIO_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
    GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
    GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_3;
    GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_Out_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    GPIO_SetBits(GPIOB,GPIO_Pin_3);
    dht11Rst();
    memset((uint8_t *)&temphumTypedef, 0, sizeof(thTypedef_t));
    USART1_printf("dh11Init \r\n");
    return dht11Check();
#include "main.h"
#include "bsp_protocol.h"
#include "bsp_product.h"
/* 变量定义 */
volatile  u32 time = 0; // ms 计时变量
uint16_t  Time_Count = 0;
uint16_t  Time_nSec_Count = 0;
uint8_t usart1_flag_change_enable = 0;//USART1 标识变更使能 0: 禁止修改标识 1: 允许修改标识
uint8_t usart2_flag_change_enable = 0;//USART2 标识变更使能 0: 禁止修改标识 1: 允许修改标识
uint8_t usart3_flag_change_enable = 0;//USART3 标识变更使能 0: 禁止修改标识 1: 允许修改标识
uint8_t uart2_acceptData_timeout_count_enable = 0;//USART2 接收数据计时使能 0: 计时关闭 1: 计时打开
uint8_t Feed_Dog_Flag = 0;//喂狗标识
uint8_t usart1_acceptData_success_flag = 0;//USART1 数据接收完成标识
uint8_t usart2_acceptData_success_flag = 0;//USART2 数据接收完成标识
uint8_t usart3_acceptData_success_flag = 0;//USART3 数据接收完成标识
uint8_t uart2_acceptData_timeout_flag = 0;//USART2 接收数据超时标识
#define        GPIO_KEY_NUM       2     ///< Defines the total number of key member
keyTypedef_t   singleKey[GPIO_KEY_NUM]; ///< Defines a single key member array pointer
keysTypedef_t  keys;
*系统复位
* __set_FAULTMASK(1);      // 关闭所有中端
* NVIC_SystemReset();       // 复位
void SystemReset(void)
* key1 short press handle
* @param none
* @return none
void key1ShortPress(void)
    USART1_printf("KEY1 PRESS ,Production Mode\n");
    gizwitsSetMode(WIFI_PRODUCTION_TEST);
* key1 long press handle
* @param none
* @return none
void key1LongPress(void)
    USART1_printf("KEY1 PRESS LONG ,Wifi Reset\n");
    gizwitsSetMode(WIFI_RESET_MODE);
* key2 short press handle
* @param none
* @return none
void key2ShortPress(void)
    USART1_printf("KEY2 PRESS ,Soft AP mode\n");
   ledRgbControl(250,0,0);///SoftAPmode,RGB red
    #if !MODULE_TYPE
    #endif
* key2 long press handle
* @param none
* @return none
void key2LongPress(void)
    //AirLink mode
    USART1_printf("KEY2 PRESS LONG ,AirLink mode\n");
   ledRgbControl(0,250,0);//AirLink mode,RGB Green
    #if !MODULE_TYPE
    #endif
* Key init function
* @param none
* @return none
void keyInit(void)
    singleKey[0] = keyInitOne(NULL, KEY1_GPIO_Port,KEY1_Pin, key1ShortPress, key1LongPress);
    singleKey[1] = keyInitOne(NULL, KEY2_GPIO_Port,KEY2_Pin, key2ShortPress, key2LongPress);
    keys.singleKey = (keyTypedef_t *)&singleKey;
    keyParaInit(&keys);
* t : 定时时间
* Ticks : 多少个时钟周期产生一次中断
* f : 时钟频率 72000000
* t = Ticks * 1/f = (72000000/100000) * (1/72000000) = 10us
void system_init(void)
SysTick_Init();/*配置SysTick 为10us中断一次 */
USART1_Config();/* USART2 配置模式为 115200 8-N-1,中断接收 */
USART2_Config();/* USART2 配置模式为 9600 8-N-1,中断接收 */
USART1_printf( "\r\nWF-esp8266 WiFi模块测试例程\r\n" ); //打印测试例程提示信息
TIM2_Configuration();/*定时器2中断配置*/
TIM2_NVIC_Configuration();/*TIM2中断优先级配置*/
    IWDG_Configuration();//看门狗初始化
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 , ENABLE);/* TIM2 重新开时钟,开始计时 */
//LED_Init ();
Key_GPIO_Config();
gizwitsInit();
//STM32_Flash_read();
keyInit();
userInit();
USART1_printf("MCU Init Success \n");
  * @brief  主函数
  * @param  无
  * @retval 无
int main(void)
system_init();
clean_uart1_rebuff();//清空了接收缓冲区数据
clean_uart2_rebuff();//清空了接收缓冲区数据
usart1_flag_change_enable = 1;//USART1 标识变更使能 0: 禁止修改标识 1: 允许修改标识
  usart2_flag_change_enable = 1;//USART1 标识变更使能 0: 禁止修改标识 1: 允许修改标识
while(1)
      if(Feed_Dog_Flag == 1)                   //喂狗
              Feed_Dog_Flag = 0;
              IWDG_ReloadCounter();              //重装载IWDG计数器 喂狗
      if(usart1_acceptData_success_flag == 1)  //USART1 数据接收完成
        usart1_flag_change_enable = 0;       //USART1 标识变更使能 0: 禁止修改标识 1: 允许修改标识
           USART1_datadeal();                   //接收数据处理
        clean_uart1_rebuff();                //清空了接收缓冲区数据
        usart1_flag_change_enable = 1;       //USART1标识变更使能 0: 禁止修改标识 1: 允许修改标识
       userHandle();
       gizwitsHandle((dataPoint_t *)¤tDataPoint);
ESP8266_TEST06_机智云.zip
466.71 KB, 下载次数: 0, 下载积分: 威望 1
