查看: 4971|回复: 0
安信可公司机智云代码求助
发表于 2016-4-25 10:22:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
gizwits_cloud_receive(const unsigned char *pdata, unsigned short length)
        // Get device status
        if (length == 1 && pdata[0] == 0x02)
                uint8 mcu_data[6];
                mcu_data[0] = 0x03;
                mcu_status_t * mcu_status;
                mcu_status = (mcu_status_t *)(&mcu_data[1]);
                mcu_status->on_off = local_mcu_status.on_off;
                mcu_status->temperature = local_mcu_status.temperature;
                mcu_status->mode = local_mcu_status.mode;
                mcu_status->brightness = local_mcu_status.brightness;
                mcu_status->color_r = local_mcu_status.color_r;
                mcu_status->color_g = local_mcu_status.color_g;
                mcu_status->color_b = local_mcu_status.color_b;
                gizwits_cloud_send(mcu_data, sizeof(mcu_data) / sizeof(uint8));
                gizwits_lan_tcp_server_dev2app(mcu_data, sizeof(mcu_data) / sizeof(uint8));
        else if (length == 7 && pdata[0] == 0x01)
                // attr_flags indicate that the corresponding bit is effective, 1 means effective, while 0 means not
                // effective.From right to left order:
                // bit0: settingSwitch
                // bit1: settingC_Temperature
                // bit2: settingmode
                // bit3: settingBrightness
                // bit4: settingColor_R
                // bit5: settingColor_G
                // bit6: settingColor_B
                mcu_attr_flags_t *mcu_attr_flags = (mcu_attr_flags_t *)(&pdata[1]);
                mcu_status = (mcu_status_t *)(&pdata[2]);
                if (mcu_attr_flags->setting_on_off)
                        local_mcu_status.on_off = mcu_status->on_off;
                        os_printf("setting_on_off:%d\r\n", mcu_status->on_off);
                if (mcu_attr_flags->setting_temperature)
                        local_mcu_status.temperature = mcu_status->temperature;
                        os_printf("setting_temperature:%d\r\n", mcu_status->temperature);
                if (mcu_attr_flags->setting_mode)
                        local_mcu_status.mode = mcu_status->mode;
                        os_printf("setting_mode:%d\r\n", mcu_status->mode);
                if (mcu_attr_flags->setting_brightness)
                        local_mcu_status.brightness = mcu_status->brightness;
                        os_printf("setting_brightness:%d\r\n", mcu_status->brightness);
                if (mcu_attr_flags->setting_color_r)
                        local_mcu_status.color_r = mcu_status->color_r;
                        os_printf("setting_color_r:%d\r\n", mcu_status->color_r);
                if (mcu_attr_flags->setting_color_g)
                        local_mcu_status.color_g = mcu_status->color_g;
                        os_printf("setting_color_g:%d\r\n", mcu_status->color_g);
                if (mcu_attr_flags->setting_color_b)
                        local_mcu_status.color_b = mcu_status->color_b;
                        os_printf("setting_color_b:%d\r\n", mcu_status->color_b);
                gizwits_app_apply_settings();
                gizwits_app_save();
                uint8 mcu_data[6];
                mcu_data[0] = 0x03;
谁能帮忙解释一下这段代码?开发板是安信可公司的机智云开发板
