查看: 53774|回复: 0
[问答] ubuntu遇到了 dpkg was interrupted, you must manually run 'dpkg..的问题
65
发表于 2017-1-13 10:34:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近,在ubuntu下安装应用程序的时候总是提示:
[html] view plain copy
print?
  • dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem. E: _cache->open() failed, please report.
上网搜索了一下中文网站,里边没有能解决问题的,于是上了ubuntu国外论坛,在里面搜索,终于解决问题了:
代码如下
print?
  • sudo dpkg --configure -a
Enter your password when prompted. Then try
print?
  • sudo apt-get update
  • followed by
  • sudo apt-get upgrade
If you've already tried this or you try it now and it isn't working then post the full output from apt-get here.
What package was being installed when apt-get failed? You should be able to see this in the output just prior to the error message you've shown.
http://blog.csdn.net/gudujianjsk/article/details/7893156
最后又在终端出现了这样的一个问题:、
libc6-dev:依赖:libc6(=2.9-4ubuntu6.1) 但是2.9-Ubuntu6已经安装了  E:不能满足依赖关系。不妨试一下-f选项     于是我在终端输入sudo apt-get -f install
问题得到解决!
