查看: 24385|回复: 3
【已解决】获取匿名用户、获取token提示appid invalid
5
发表于 2016-1-1 14:12:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发起请求:
  1. <?php
  2. function curl_post($url,$data='',$timeout=30,$header=array()){
  3.         $arrCurlResult = array();
  4.         $ch = curl_init();
  5.         curl_setopt($ch, CURLOPT_HTTPHEADER, $header);
  6.         curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, true);//ssl检测跳过
  7.         curl_setopt($ch, CURLOPT_URL, $url);
  8.         curl_setopt($ch, CURLOPT_POST, true);
  9.         curl_setopt($ch, CURLOPT_POSTFIELDS,$data);
  10.         curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
  11.         curl_setopt($ch, CURLOPT_HEADER, false);
  12.         curl_setopt($ch, CURLOPT_TIMEOUT, $timeout);
  13.         curl_setopt ( $ch,CURLOPT_REFERER,"");
  14.         $output = curl_exec($ch);
  15.         $responseCode = curl_getinfo($ch,CURLINFO_HTTP_CODE);
  16.         $arrCurlResult['output'] = $output;//返回结果
  17.         $arrCurlResult['code'] = $responseCode;//返回http状态
  18.         curl_close($ch);
  19.         unset($ch);
  20.         return $arrCurlResult;
  21. }
  22. $header=array(
  23.         'Content-Type:application/json',
  24.         'X-Gizwits-Application-Id:d144ac6422ca444d8345xxxxxxxx'//appid隐藏了
  25. );
  26. $params=array(
  27.         "phone_id"=> "apiary"
  28. );
  29. $params_query=json_encode($params);
  30. $result=@curl_post('http://api.gizwits.com/app/users',$params_query,$header,30);
  31. echo '<pre>';
  32. print_r($result);
  33. ?>
返回内容:
Array(    [output] => {"error_message":"appid invalid!","error_code":9003,"detail_message":null}    [code] => 400)
5
 楼主| 发表于 2016-1-1 14:26:58 | 只看该作者
已解决,发现是参数写错了额
发表于 2016-3-30 11:43:29 | 只看该作者
您好,我最近也在用新浪云上的PHP代码调用机智云的Open API ,能交流下吗?我的qq是615838972,谢谢您!!!
发表于 2016-3-30 19:18:53 | 只看该作者
