查看: 40511|回复: 2
第一章 GoKit的板载硬件离线控制:按键长按、短按识别
14
超级版主
发表于 2016-1-4 11:56:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
第一章 gokit的板载硬件离线控制:按键长按、短按识别
智能宠物屋 GoKit
arduino程序:
File Name:protocol.cpp
Path:GoKit_2_MCU_Arduino-master\GoKit_2_MCU_Arduino\protocol.cpp
DownLoad:https://git.oschina.net/dantang/GoKit_2_MCU_Arduino
void Handle_keyeven()
  /*  长按是指按住按键3s以上   */
  switch(gokit_keydown())
    case KEY1_SHORT_PRESS:                   //Key1 短按识别
       #if (DEBUG==1)
        Serial.println("KEY1_SHORT_PRESS");
       #endif
    break;
    case KEY1_LONG_PRESS:                    //Key1 长按识别
      #if (DEBUG==1)
        Serial.println("KEY1_LONG_PRESS");
       #endif
        gokit_ResetWiFi();                   //重启WiFi配置
    break;
    case KEY2_SHORT_PRESS:                   //Key2 短按识别
       #if (DEBUG==1)
        Serial.println("KEY2_SHORT_PRESS");
       #endif
          gokit_sendAirlink();               //进入AirLink配置模式
    break;
    case KEY2_LONG_PRESS:                    //Key2 长按识别
       #if (DEBUG==1)
        Serial.println("KEY2_LONG_PRESS");
       #endif
       gokit_sendApCmd();                    //进入SoftAp配置模式
    break;
    default: break;
  //KEY1 : D6        Arduino D6引脚设定为Key1
  //KEY2 : D7        Arduino D7引脚设定为Key1
STM32程序:
File Name:hal_key.c
Path:GoKit_2_MCU_STM-master\GoKit_2_MCU_STM\User\Hal_key\hal_key.c
DownLoad:https://git.oschina.net/dantang/GoKit_2_MCU_STM
void KEY_GPIO_Init(void)                 //Key GPIO初始化定义
        GPIO_InitTypeDef GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(GPIO_KEY1_CLK | GPIO_KEY2_CLK | GPIO_KEY3_CLK, ENABLE);
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_InitStructure.GPIO_Pin = GPIO_KEY1_PIN;
        GPIO_Init(GPIO_KEY1_PORT, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_KEY2_PIN;
        GPIO_Init(GPIO_KEY2_PORT, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_KEY3_PIN;
        GPIO_Init(GPIO_KEY3_PORT, &GPIO_InitStructure);
void KEY_LongHandle(uint8_t KeyAction)       //Key1 、 Key2 长按处理
        if(KeyAction  == KEY1_Long_Action)
                Device_WirteStruct.LED_R = 50;             //设备写入RGB R色值
                Device_WirteStruct.LED_G = 0;              //设备写入RGB G色值
                Device_WirteStruct.LED_B = 0;             //设备写入RGB B色值
                LED_RGB_Control(Device_WirteStruct.LED_R,Device_WirteStruct.LED_G,Device_WirteStruct.LED_B);
                //LED控制RGB色值
                Pro_M2WResetCmdStruct.Pro_HeadPart.SN = SN++;
                Pro_M2WResetCmdStruct.Sum = CheckSum((uint8_t *)&Pro_M2WResetCmdStruct, sizeof(Pro_M2WResetCmdStruct));
                Pro_UART_SendBuf((uint8_t *)&Pro_M2WResetCmdStruct,sizeof(Pro_M2WResetCmdStruct), 0);
        if(KeyAction  == KEY2_Long_Action)
                Device_WirteStruct.LED_R = 0;           //设备写入RGB R色值
                Device_WirteStruct.LED_B = 50;          //设备写入RGB B色值
                //LED控制RGB色值
                Pro_D2WConfigCmdStruct.Pro_HeadPart.SN = SN++;
                Pro_D2WConfigCmdStruct.Config_Method = 0x02;
                Pro_D2WConfigCmdStruct.Sum = CheckSum((uint8_t *)&Pro_D2WConfigCmdStruct, sizeof(Pro_D2WConfigCmdStruct));
                Pro_UART_SendBuf((uint8_t *)&Pro_D2WConfigCmdStruct,sizeof(Pro_D2WConfigCmdStruct), 0);
150
管理员
Rank: 9Rank: 9Rank: 9
发表于 2016-1-4 12:08:42 | 只看该作者
,大哥,这是逼我给你看专栏的节奏吗?
发表于 2016-1-4 12:53:05 | 只看该作者
不贴代码,不加说明,意义不是很大吧
