查看: 25378|回复: 1
历史数据api devdata2 出错
发表于 2015-3-22 13:48:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用curl调用这个api,返回如下的错误结果:
curl --include      --header "Content-Type: application/json"      --header "X-Gizwits-Application-Id: ecb16888bb794c68b15606f8247f3e31"   'http://api.gizwits.com/app/devdata2?product_key=e3cf7332b7834a03a92d9e14a3f6d352&start_ts=1349032093&end_ts=1349042093&name=temp&limit=20&skip=0'
<h3>The page you are looking for is temporarily unavailable.  Please try again later.</h3>
            <div class="alert">
                <h2>Website Administrator</h2>
                <div class="content">
                    <p>Something has triggered an error on your
                    website.  This is the default error page for
                    <strong>nginx</strong> that is distributed with
                    EPEL.  It is located
                    <tt>/usr/share/nginx/html/50x.html</tt></p>
                    <p>You should customize this error page for your own
                    site or edit the <tt>error_page</tt> directive in
                    the <strong>nginx</strong> configuration file
                    <tt>/etc/nginx/nginx.conf</tt>.</p>
                </div>
            </div>
能不能帮忙看下呢?
5
发表于 2015-4-21 15:41:57 | 只看该作者
楼主您好,不知道目前问题解决了没?
