查看: 5084|回复: 0
ESP8266学习笔记5:ESP8266接入yeelink(转)
34
超级版主
发表于 2016-7-13 14:30:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
版权**:本文为博主原创文章,未经博主允许不得转载。
目录(?)[+]
搞定了SmartConfig,前头也用cURL玩过了yeelink,今天就编写代码,让esp8266接入yeelink。
转载请注明:http://blog.csdn.net/sadshen/article/details/46897479
一、代码处理。
主要是将http的sample加入到SmartConfig_DEMO中。ESP8266的运行流程是SmartConfig->DNS->Connect yeelink->Get /devices
这里的pheadbuffer 格式要注意加上U-ApiKey。我是通过wireshark捕捉了curl Get /devices的动作才知道要怎么写的。
[cpp] view plain copy
  • #include "ets_sys.h"
  • #include "osapi.h"
  • #include "user_interface.h"
  • #include "smartconfig.h"
  • #include "espconn.h"
  • #include "mem.h"
  • #define NET_DOMAIN "api.yeelink.net"
  • #define pheadbuffer "GET /v1.0/devices HTTP/1.1\r\nHost: %s\r\nAccept: */*\r\nU-ApiKey: e510ad132988d34c6fc9c3a9322f6f10\r\n\r\n"
  • #define packet_size   (2 * 1024)
  • LOCAL os_timer_t test_timer;
  • LOCAL struct espconn user_tcp_conn;
  • LOCAL struct _esp_tcp user_tcp;
  • ip_addr_t tcp_server_ip;
  • * FunctionName : user_tcp_recv_cb
  • * Description  : receive callback.
  • * Parameters   : arg -- Additional argument to pass to the callback function
  • * Returns      : none
  • LOCAL void ICACHE_FLASH_ATTR
  • user_tcp_recv_cb(void *arg, char *pusrdata, unsigned short length)
  •    //received some data from tcp connection
  •     os_printf("tcp recv !!! %s \r\n", pusrdata);
  • * FunctionName : user_tcp_sent_cb
  • * Description  : data sent callback.
  • * Returns      : none
  • user_tcp_sent_cb(void *arg)
  •    //data sent successfully
  •     os_printf("tcp sent succeed !!! \r\n");
  • * FunctionName : user_tcp_discon_cb
  • * Description  : disconnect callback.
  • * Returns      : none
  • user_tcp_discon_cb(void *arg)
  •    //tcp disconnect successfully
  •     os_printf("tcp disconnect succeed !!! \r\n");
  • * FunctionName : user_esp_platform_sent
  • * Description  : Processing the application data and sending it to the host
  • * Parameters   : pespconn -- the espconn used to connetion with the host
  • * Returns      : none
  • user_sent_data(struct espconn *pespconn)
  •     char *pbuf = (char *)os_zalloc(packet_size);
  •     os_sprintf(pbuf, pheadbuffer, NET_DOMAIN);
  •     espconn_sent(pespconn, pbuf, os_strlen(pbuf));
  •     os_free(pbuf);
  • * FunctionName : user_tcp_connect_cb
  • * Description  : A new incoming tcp connection has been connected.
  • * Returns      : none
  • user_tcp_connect_cb(void *arg)
  •     struct espconn *pespconn = arg;
  •     os_printf("connect succeed !!! \r\n");
  •     espconn_regist_recvcb(pespconn, user_tcp_recv_cb);
  •     espconn_regist_sentcb(pespconn, user_tcp_sent_cb);
  •     espconn_regist_disconcb(pespconn, user_tcp_discon_cb);
  •     user_sent_data(pespconn);
  • * FunctionName : user_tcp_recon_cb
  • * Description  : reconnect callback, error occured in TCP connection.
  • * Returns      : none
  • user_tcp_recon_cb(void *arg, sint8 err)
  •    //error occured , tcp connection broke. user can try to reconnect here.
  •     os_printf("reconnect callback, error code %d !!! \r\n",err);
  • * FunctionName : user_dns_found
  • * Description  : dns found callback
  • * Parameters   : name -- pointer to the name that was looked up.
  • *                ipaddr -- pointer to an ip_addr_t containing the IP address of
  • *                the hostname, or NULL if the name could not be found (or on any
  • *                other error).
  • *                callback_arg -- a user-specified callback argument passed to
  • *                dns_gethostbyname
  • * Returns      : none
  • user_dns_found(const char *name, ip_addr_t *ipaddr, void *arg)
  •     struct espconn *pespconn = (struct espconn *)arg;
  •     if (ipaddr == NULL) {
  •         os_printf("user_dns_found NULL \r\n");
  •         return;
  •     //dns got ip
  •     os_printf("user_dns_found %d.%d.%d.%d \r\n",
  •             *((uint8 *)&ipaddr->addr), *((uint8 *)&ipaddr->addr + 1),
  •             *((uint8 *)&ipaddr->addr + 2), *((uint8 *)&ipaddr->addr + 3));
  •     if (tcp_server_ip.addr == 0 && ipaddr->addr != 0) {
  •         // dns succeed, create tcp connection
  •         os_timer_disarm(&test_timer);
  •         tcp_server_ip.addr = ipaddr->addr;
  •         os_memcpy(pespconn->proto.tcp->remote_ip, &ipaddr->addr, 4); // remote ip of tcp server which get by dns
  •         pespconn->proto.tcp->remote_port = 80; // remote port of tcp server
  •         pespconn->proto.tcp->local_port = espconn_port(); //local port of ESP8266
  •         espconn_regist_connectcb(pespconn, user_tcp_connect_cb); // register connect callback
  •         espconn_regist_reconcb(pespconn, user_tcp_recon_cb); // register reconnect callback as error handler
  •         espconn_connect(pespconn); // tcp connect
  • * FunctionName : user_esp_platform_dns_check_cb
  • * Description  : 1s time callback to check dns found
  • * Returns      : none
  • user_dns_check_cb(void *arg)
  •     espconn_gethostbyname(pespconn, NET_DOMAIN, &tcp_server_ip, user_dns_found); // recall DNS function
  •     os_printf("dns_check\n");
  •     os_timer_arm(&test_timer, 1000, 0);
  • * FunctionName : CheckIpStart
  • * Description  : set the router info which ESP8266 station will connect to
  • * Parameters   : none
  • * Returns      : none
  • void ICACHE_FLASH_ATTR
  • CheckIpStart(void)
  •     // Connect to tcp server as NET_DOMAIN
  •     user_tcp_conn.proto.tcp = &user_tcp;
  •     user_tcp_conn.type = ESPCONN_TCP;
  •     user_tcp_conn.state = ESPCONN_NONE;
  •     tcp_server_ip.addr = 0;
  •     espconn_gethostbyname(&user_tcp_conn, NET_DOMAIN, &tcp_server_ip, user_dns_found); // DNS function
  •     os_timer_setfn(&test_timer, (os_timer_func_t *)user_dns_check_cb, user_tcp_conn);
  • smartconfig_done(sc_status status, void *pdata)
  •     switch(status) {
  •         case SC_STATUS_WAIT:
  •             os_printf("SC_STATUS_WAIT\n");
  •             break;
  •         case SC_STATUS_FIND_CHANNEL:
  •             os_printf("SC_STATUS_FIND_CHANNEL\n");
  •             break;
  •         case SC_STATUS_GETTING_SSID_PSWD:
  •             os_printf("SC_STATUS_GETTING_SSID_PSWD\n");
  •             sc_type *type = pdata;
  •             if (*type == SC_TYPE_ESPTOUCH) {
  •                 os_printf("SC_TYPE:SC_TYPE_ESPTOUCH\n");
  •             } else {
  •                 os_printf("SC_TYPE:SC_TYPE_AIRKISS\n");
  •             break;
  •         case SC_STATUS_LINK:
  •             os_printf("SC_STATUS_LINK\n");
  •             struct station_config *sta_conf = pdata;
  •             wifi_station_set_config(sta_conf);
  •             wifi_station_disconnect();
  •             wifi_station_connect();
  •             break;
  •         case SC_STATUS_LINK_OVER:
  •             os_printf("SC_STATUS_LINK_OVER\n");
  •             if (pdata != NULL) {
  •                 uint8 phone_ip[4] = {0};
  •                 os_memcpy(phone_ip, (uint8*)pdata, 4);
  •                 os_printf("Phone ip: %d.%d.%d.%d\n",phone_ip[0],phone_ip[1],phone_ip[2],phone_ip[3]);
  •                 CheckIpStart();
  •             smartconfig_stop();
  •             break;
  • void user_rf_pre_init(void)
  • void user_init(void)
  •     os_printf("SDK version:%s\n", system_get_sdk_version());
  •     wifi_set_opmode(STATION_MODE);
  •     smartconfig_start(smartconfig_done);
二、测试
