查看: 72986|回复: 4
[资料] 老外开发的MicroPython IDE,可用于开发ESP8266
发表于 2016-10-8 13:28:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ESPyHarp是韩国人写的一个简单的MicroPython IDE,它可以用于esp8266上。
    Introduction
  The ESPyHarp is a simple IDE for developing MicroPython program. It’s target board is ESP8266 based boards (e.g. NodeMCU) with MicroPython firmware. I like both ESP8266 and MicroPython. However, I had found the fact that there is no useful development tool (or IDE). So, I started to develop IDE for  personal use and named it ESPyHarp. It is written using JavaFX and an open source libraries such as RichTextFX, jSSC, etc. You can see or download the source code in github.com page.
Features
  • embedded REPL
  • files list in the device
  • code editor with python keyword and builtins highlight
  • upload and/or execute  python script
    Requirements
     You need JVM(Java Virtual Machine) on your PC to run ESPyHarp. Then, download the released file below and execute ESPyHarp.jar file. On Windows you can run the jar file just double clicking on it. At this moment, I have tested only on Windows 7 PC.
     Releases
         ESPyHarp_v011.zip (912.55 KB, 下载次数: 6, 售价: 1 金钱) (03/Oct/2016) : minor REPL bug fix
         ESPyHarp_v010.zip (912.95 KB, 下载次数: 14) (01/Oct/2016) : initial release
官方网站:http://studymake.tistory.com/584
GitHub地址:https://github.com/salesiopark/ESPyHarp
5
发表于 2016-10-8 13:39:53 | 只看该作者
表示国内小白看后充满无力感。
知行合一
发表于 2016-10-12 09:11:13 | 只看该作者
,等待后续更新
发表于 2018-4-26 16:34:18 | 只看该作者
许许 发表于 2016-10-8 13:39
表示国内小白看后充满无力感。
哈哈哈,要不要试试看国内独立开发的Micropython IDE:uPyCraft。
在线文档地址是http://docs.dfrobot.com.cn/upycraft/
章节中支持免安装在线下载~
发表于 2019-8-20 17:55:23 | 只看该作者
在线文档地址是http://docs.dfrobot.com ...
感谢大神
