查看: 47860|回复: 1
[技术分享] android6.0权限申请
45
发表于 2017-3-6 15:28:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
6.0权限的基本知识,以下是需要单独申请的权限,共分为9组,每组只要有一个权限申请成功了,就默认整组权限都可以使用了。
  group:android.permission-group.CONTACTS
    permission:android.permission.WRITE_CONTACTS
    permission:android.permission.GET_ACCOUNTS
    permission:android.permission.READ_CONTACTS
  group:android.permission-group.PHONE
    permission:android.permission.READ_CALL_LOG
    permission:android.permission.READ_PHONE_STATE
    permission:android.permission.CALL_PHONE
    permission:android.permission.WRITE_CALL_LOG
    permission:android.permission.USE_SIP
    permission:android.permission.PROCESS_OUTGOING_CALLS
    permission:com.android.voicemail.permission.ADD_VOICEMAIL
  group:android.permission-group.CALENDAR
    permission:android.permission.READ_CALENDAR
    permission:android.permission.WRITE_CALENDAR
  group:android.permission-group.CAMERA
    permission:android.permission.CAMERA
  group:android.permission-group.SENSORS
    permission:android.permission.BODY_SENSORS
  group:android.permission-group.LOCATION
    permission:android.permission.ACCESS_FINE_LOCATION
    permission:android.permission.ACCESS_COARSE_LOCATION
  group:android.permission-group.STORAGE
    permission:android.permission.READ_EXTERNAL_STORAGE
    permission:android.permission.WRITE_EXTERNAL_STORAGE
  group:android.permission-group.MICROPHONE
    permission:android.permission.RECORD_AUDIO
  group:android.permission-group.SMS
    permission:android.permission.READ_SMS
    permission:android.permission.RECEIVE_WAP_PUSH
    permission:android.permission.RECEIVE_MMS
    permission:android.permission.RECEIVE_SMS
    permission:android.permission.SEND_SMS
    permission:android.permission.READ_CELL_BROADCASTS
以下是普通权限,只需要在AndroidManifest.xml中申请即可。
  android.permission.ACCESS_LOCATION_EXTRA_COMMANDS
  android.permission.ACCESS_NETWORK_STATE
  android.permission.ACCESS_NOTIFICATION_POLICY
  android.permission.ACCESS_WIFI_STATE
  android.permission.ACCESS_WIMAX_STATE
  android.permission.BLUETOOTH
  android.permission.BLUETOOTH_ADMIN
  android.permission.BROADCAST_STICKY
  android.permission.CHANGE_NETWORK_STATE
  android.permission.CHANGE_WIFI_MULTICAST_STATE
  android.permission.CHANGE_WIFI_STATE
  android.permission.CHANGE_WIMAX_STATE
  android.permission.DISABLE_KEYGUARD
  android.permission.EXPAND_STATUS_BAR
  android.permission.FLASHLIGHT
  android.permission.GET_PACKAGE_SIZE
  android.permission.INTERNET
  android.permission.KILL_BACKGROUND_PROCESSES
  android.permission.MODIFY_AUDIO_SETTINGS
  android.permission.NFC
  android.permission.READ_SYNC_SETTINGS
  android.permission.READ_SYNC_STATS
  android.permission.RECEIVE_BOOT_COMPLETED
  android.permission.REORDER_TASKS
  android.permission.REQUEST_INSTALL_PACKAGES
  android.permission.SET_TIME_ZONE
  android.permission.SET_WALLPAPER
  android.permission.SET_WALLPAPER_HINTS
  android.permission.SUBSCRIBED_FEEDS_READ
  android.permission.TRANSMIT_IR
  android.permission.USE_FINGERPRINT
  android.permission.VIBRATE
  android.permission.WAKE_LOCK
  android.permission.WRITE_SYNC_SETTINGS
  com.android.alarm.permission.SET_ALARM
  com.android.launcher.permission.INSTALL_SHORTCUT
  com.android.launcher.permission.UNINSTALL_SHORTCUT
申请步骤
将targetSdkVersion设置为23,注意,如果你将targetSdkVersion设置为>=23,则必须按照Android谷歌的要求,动态的申请权限,如果你暂时不打算支持动态权限申请,则targetSdkVersion最大只能设置为22.
2 在AndroidManifest.xml中申请你需要的权限,包括普通权限和需要申请的特殊权限。
3.开始申请权限,此处分为3部。
(1)检查是否由此权限checkSelfPermission(),如果已经开启,则直接做你想做的。
(2)如果未开启,则判断是否需要向用户解释为何申请权限shouldShowRequestPermissionRationale。
(3)如果需要(即返回true),则可以弹出对话框提示用户申请权限原因,用户确认后申请权限requestPermissions(),如果不需要(即返回false),则直接申请权限requestPermissions()。
(这里是一部门代码,底部有比较完善的代码,整个demo可以在github中下载)。
9
发表于 2017-7-11 18:53:46 | 只看该作者
楼主,我的想法和你不一样。如果只是设置targetSdkVersion的版本,那么 我的系统6.0就无法使用某项功能了。所以,这个权限适配工作是在代码实现的,先判断当前手机是否6.0或以上,再进行动态授权。否则,某些国产手机是默认拒绝你的这个权限的,比如wifi扫描,在6.0或以上,必须打开定位权限和grps权限。 总结一句话:不要在targetSdkVersion设置版本,你只需在代码判断做不同的适配即可。
