查看: 66894|回复: 3
[问答] 按照教程生成了代码,烧录了固件,可最后就是配置不了
发表于 2018-5-5 13:53:50 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
网上买的8266模块带彩灯的,一上电是蓝绿色,按key2模块没有任何反应,根据代码使用模拟串口A2,A3所以RX接A2,TX接A3,VCC接的板载3.3V,按下按键的时候UNO板上的TX指示灯是微微闪了几下的,可模块就是没有任何反应,APP也搜索不到设备,请各位大神们指点一下
固件是最新版的04020029
固件是最新版的04020029
 楼主| 发表于 2018-5-5 13:58:14 | 只看该作者
以下是自动生成的代码,已经按照教程把两个程序的代码合并,已成功上传到UNO
#include <Gizwits.h>
#include <Wire.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(A2, A3); // A2 -> RX, A3 -> TX
Gizwits myGizwits;
#define   KEY1              6
#define   KEY2              7
#define   KEY1_SHORT_PRESS  1
#define   KEY1_LONG_PRESS   2
#define   KEY2_SHORT_PRESS  4
#define   KEY2_LONG_PRESS   8
#define   NO_KEY            0
#define   KEY_LONG_TIMER    3
unsigned long Last_KeyTime = 0;
unsigned long gokit_time_s(void)
  return millis() / 1000;
char gokit_key1down(void)
  unsigned long keep_time = 0;
  if (digitalRead(KEY1) == LOW)
    delay(100);
      keep_time = gokit_time_s();
      while (digitalRead(KEY1) == LOW)
        if ((gokit_time_s() - keep_time) > KEY_LONG_TIMER)
          Last_KeyTime = gokit_time_s();
          return KEY1_LONG_PRESS;
      } //until open the key
      if ((gokit_time_s() - Last_KeyTime) > KEY_LONG_TIMER)
        return KEY1_SHORT_PRESS;
      return 0;
    return 0;
  return 0;
char gokit_key2down(void)
  int unsigned long keep_time = 0;
  if (digitalRead(KEY2) == LOW)
    delay(100);
      while (digitalRead(KEY2) == LOW) //until open the key
          return KEY2_LONG_PRESS;
        return KEY2_SHORT_PRESS;
      return 0;
    return 0;
  return 0;
char gokit_keydown(void)
  char ret = 0;
  ret |= gokit_key2down();
  ret |= gokit_key1down();
  return ret;
* KEY_Handle
* @param none
* @return none
void KEY_Handle(void)
  /*  Press for over than 3 second is Long Press  */
  switch (gokit_keydown())
    case KEY1_SHORT_PRESS:
      mySerial.println(F("KEY1_SHORT_PRESS , Production Test Mode "));
      myGizwits.setBindMode(WIFI_PRODUCTION_TEST);
      break;
    case KEY1_LONG_PRESS:
      mySerial.println(F("KEY1_LONG_PRESS ,Wifi Reset"));
      myGizwits.setBindMode(WIFI_RESET_MODE);
      break;
    case KEY2_SHORT_PRESS:
      mySerial.println(F("KEY2_SHORT_PRESS Soft AP mode"));
      myGizwits.setBindMode(WIFI_SOFTAP_MODE);
      //Soft AP mode
      break;
    case KEY2_LONG_PRESS:
      mySerial.println(F("KEY2_LONG_PRESS ,AirLink mode"));
      myGizwits.setBindMode(WIFI_AIRLINK_MODE);
      //AirLink mode
      break;
    default:
      break;
void setup() {
  pinMode(KEY1, INPUT_PULLUP);
  pinMode(KEY2, INPUT_PULLUP);
  mySerial.begin(115200);
  myGizwits.begin();
  mySerial.println("GoKit init  OK \n");
void wifiStatusHandle()
  if(myGizwits.wifiHasBeenSet(WIFI_SOFTAP))
    mySerial.println(F("WIFI_SOFTAP!"));
  if(myGizwits.wifiHasBeenSet(WIFI_AIRLINK))
    mySerial.println(F("WIFI_AIRLINK!"));
  if(myGizwits.wifiHasBeenSet(WIFI_STATION))
    mySerial.println(F("WIFI_STATION!"));
  if(myGizwits.wifiHasBeenSet(WIFI_CON_ROUTER))
    mySerial.println(F("WIFI_CON_ROUTER!"));
  if(myGizwits.wifiHasBeenSet(WIFI_DISCON_ROUTER))
    mySerial.println(F("WIFI_DISCON_ROUTER!"));
  if(myGizwits.wifiHasBeenSet(WIFI_CON_M2M))
    mySerial.println(F("WIFI_CON_M2M!"));
  if(myGizwits.wifiHasBeenSet(WIFI_DISCON_M2M))
    mySerial.println(F("WIFI_DISCON_M2M!"));
void loop() {
  //Configure network
  //if(XXX) //Trigger Condition
  //myGizwits.setBindMode(0x02);  //0x01:Enter AP Mode;0x02:Enter Airlink Mode
  float varW_temp = 0;//Add Sensor Data Collection
  myGizwits.write(VALUE_temp, varW_temp);
  //binary datapoint handle
  KEY_Handle();//key handle , network configure
  wifiStatusHandle();//WIFI Status Handle
  myGizwits.process();
 楼主| 发表于 2018-5-5 14:58:38 | 只看该作者
为什么加Q群管理员还不同意呢
超级版主
发表于 2018-5-14 12:14:35 | 只看该作者
烧录地址填错了,看文档,附链接http://docs.gizwits.com/zh-cn/de ... AF%B4%E6%98%8E.html
