查看: 6234|回复: 0
Solid Edge ST7 发布MP8
35
发表于 2015-6-24 08:47:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Doug Stainbrook, Global  Technical Business Development
To:
Edge Answers
Subject:
Solid Edge ST7 Maintenance Pack 8 Released
Date:
06/23/2015
Distribution:
Siemens  PLM Software employees:
Yes
Channel  Partners:
Yes
Edgers,
  Solid Edge ST7 Maintenance Pack 8 for Solid Edge is available for  download.
Sincerely,
  The Solid Edge Team
  Release Notes:
Maintenance Packs are released for CRITICAL items only.  Maintenance Packs are available up to a maximum
  of 15 months following the release date of the English version. The release  date for Solid Edge ST7 English was
  08/08/14, making the Maintenance Pack cutoff date 11/08/15.
  Download Location:
ST7 Maintenance Packs can be downloaded from:
  Installation:
There were Solid Edge Embedded Client policy file updates in  MP2. It’s vitally important that you install SEEC
  Administrator, which delivers the policy files to TC_DATA.
Maintenance Pack Executables (.exe files) patch existing product  dlls. Maintenance Pack executables
  are all inclusive and can be installed on top of a base release or any  released Maintenance Pack.
Maintenance Pack Installs (.zip files) are complete product  setups. Therefore, existing versions must be
  uninstalled using Add/Remove Programs from the Control Panel prior to  installing the new setup.
  E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update  or Maintenance Packs, subscribe
  to the SFBmail notification.
To initiate your subscription, navigate to: http://support.industrysoftware. ... general/email.shtml  for the web interface.
  This Maintenance Pack addresses the following PRs:
===API===
  PR 7368046: YouTube states it will no longer support older YouTube apps
===Assembly===
  PR 7382055: Failed relations in replace part with copy
  PR 7377429: Dimension on Sync cylindrical face not shown if an assembly  feature modifies part
  PR 8266419: Path edits does not cause Frame feature to update
  PR 7382761: Performance issue opening an assembly file
  PR 7400876: Animation editor does not work
===Draft===
  PR 7316543: Wrong result when copy-paste table in draft.
  PR 7332149: Callout doesn't handle Chinese + Cyrillic chars from  DraftCallout.txt correctly
  PR 7384367: Parenthesis indicating reference dim are interfering with dual  dimension bracket
  PR 7396466: Draft - Copy/paste and attempted parts list placement crashed
  PR 7395989: Incorrect dimension scale on Import of DXF files
  PR 8505242: Dimension changes when opening this drawing file in SE ST7
===Part/Profile/Sheet Metal===
  PR 7387755: Solid Edge crashes after clicking cancel on warning dialog
  PR 7399116: Hole feature problem since ST7MP7
  PR 7280647: Smart dimension value differs from curve length about 0.5 mm
  PR 7405986: Solid Edge closes with 'System is Low on Memory' error
===Translators===
  PR 1991413: SolidEdgeTranslationServices.exe cannot run multithreaded
===Insight===
  PR 7373760: Slow key-in in Property Manager- Insight actions during edit
  PR 7378436: Search Dialog "Results per page:" row is misaligned
  PR 2249492: Property Manager errors when changing properties of parts
  PR 7396003: Insight Free Text search returns only one file for same filename  in diff folders
===Solid Edge SP, Server, Standalone Client, Solid Edge  Client===
  PR 7390126: Error during upload to SESP when unmanaged parts are inserted in  a managed assembly
  PR 7370133: Workflow with option "beliebig" (any) doesn't work on a  German SESP Server
  PR 7402064: DP - Modify Tool does not create tmp file for tif files (any  image file)
===Solid Edge Embedded Client===
  PR 7371603: Dimensions values are rounded down with SEEC in French version
  PR 8505291: Solid Edge check out SEEC license when SEEC is turn off
  PR 8270039: Variables values are rounded down on FOP with SEEC in French  version
  PR 7402020: When do not specify a variant the assembly will be blank after it  is open
  PR 8270157: SEEC - sub-classed item type missing forms
  PR 7408247: Change Ownership on SE Assembly doesn't change attached Form
  PR 8271312: Material property sync causes doubled Edge.exe process
To access the current Edge Answers, Employees and Partners can  click the following link.
  https://sales.industrysoftware.a ... /Solid-Edge-Answers
Happy selling!!
Doug Stainbrook
  Senior Application Engineer
备注:此补丁也可从QQ群14882199的群共享空间下载获得。
很抱歉由于微信水印的原因,图片显示不出来~~~现在正在努力想办法~~~
