查看: 10788|回复: 0
[经验分享] [经验分享] [OpenWrt]编译记录2
57
发表于 2017-11-24 19:03:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
# 前言
开发板flash为w25q256,是16MByte的,所以需要修改分区表.
# 新建profile
使用下面命令创建一个属于自己的profile(修改会更方便一些,我们直接拷贝一个,然后再修改)
    cd target/linux/ramips/mt7628/profiles/
    cp 00-default.mk 01-gizwits.mk
修改后的01-gizwits.mk文件如下
    # Copyright (C) 2011 OpenWrt.org
    # This is free software, licensed under the GNU General Public License v2.
    # See /LICENSE for more information.
    define Profile/GizWits
        PACKAGES:=\
            kmod-usb-core kmod-usb2 kmod-usb-ohci \
                   kmod-ledtrig-usbdev
    endef
    define Profile/GizWits/Description
            Default package set compatible with most boards.
    endef
    $(eval $(call Profile,GizWits))
# 新建dts文件
同理,我们基于MT7628.dts,新建一个dts文件。
    cd ../../dts/ #切换目录到target/linux/ramips/dts/
    cp MT7628.dts GIZWITS.dts
修改GIZWITS.dts,以适配开发板的flash,修改后的GIZWITS.dts
    model = "Mediatek MT7628AN evaluation board for Gizwits";
            palmbus@10000000 {
                spi@b00 {
                        status = "okay";
                        m25p80@0 {
                                #address-cells = <1>;
                                #size-cells = <1>;
                                compatible = "w25q256";
                                reg = <0 0>;
                                linux,modalias = "m25p80", "w25q256";
                                spi-max-frequency = <10000000>;
                                m25p,chunked-io = <32>;
                                partition@0 {
                                        label = "u-boot";
                                        reg = <0x0 0x30000>;
                                        read-only;
                                partition@30000 {
                                        label = "u-boot-env";
                                        reg = <0x30000 0x10000>;
                                        read-only;
                                factory: partition@40000 {
                                        label = "factory";
                                        reg = <0x40000 0x10000>;
                                        read-only;
                                partition@50000 {
                                        label = "firmware";
                                        reg = <0x50000 0xfb0000>;
# 修改image/Makefile文件
目录target/linux/ramips/image
    cd ../image
找到MT7628对应的位置,添加我们的支持
    # MT7628 Profiles
    Image/Build/Profile/MT7628=$(call BuildFirmware/Default4M/$(1),$(1),mt7628,MT7628)
    Image/Build/Profile/GizWits=$(call BuildFirmware/Default16M/$(1),$(1),GizWits,GIZWITS)
    ifeq ($(SUBTARGET),mt7628)
    define Image/Build/Profile/Default
            $(call Image/Build/Profile/MT7628,$(1))
            $(call Image/Build/Profile/GizWits,$(1))
    endef
    endif
# 编译测试
要使新的profile生效,需要删除tmp目录并重新选择profile
    cd ~/openwrt
    rm -rf tmp
    make menuconfig
在配置页面中选择新建的profile
    Target Profile --->
        GizWits Profile
重新编译可得到新的固件文件
    make V=s
可在bin/ramips中看到新生成的bin文件openwrt-ramips-mt7628-GizWits-squashfs-sysupgrade.bin
# 参考
> http://blog.csdn.net/kobe_zero/article/details/51769635
> http://blog.csdn.net/hnhkj/article/details/54630098
