查看: 3381|回复: 0
智能灯 arduino总是报错
发表于 2017-12-10 15:05:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
我按照这篇文档做的《30分钟用arduino开发属于自己智能灯》,库文件都已经放在libiaries里面了,但是还是报错
我修改后的代码是这个
#include <Gizwits.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <ChainableLED.h>
SoftwareSerial mySerial(A2, A3); // A2 -> RX, A3 -> TX
Gizwits myGizwits;
#define   KEY1              6
#define   KEY2              7
#define   KEY1_SHORT_PRESS  1
#define   KEY1_LONG_PRESS   2
#define   KEY2_SHORT_PRESS  4
#define   KEY2_LONG_PRESS   8
#define   NO_KEY            0
#define   KEY_LONG_TIMER    3
unsigned long Last_KeyTime = 0;
uint8_t Set_LedStatus = 0;
ChainableLED leds(A5,A4,1);
void LED_RGB_Control(byte red,byte green,byte blue)
  leds.setColorRGB(0,red,green,blue);
unsigned long gokit_time_s(void)
  return millis() / 1000;
char gokit_key1down(void)
  unsigned long keep_time = 0;
  if (digitalRead(KEY1) == LOW)
    delay(100);
      keep_time = gokit_time_s();
      while (digitalRead(KEY1) == LOW)
        if ((gokit_time_s() - keep_time) > KEY_LONG_TIMER)
          Last_KeyTime = gokit_time_s();
          return KEY1_LONG_PRESS;
      } //until open the key
      if ((gokit_time_s() - Last_KeyTime) > KEY_LONG_TIMER)
        return KEY1_SHORT_PRESS;
      return 0;
    return 0;
  return 0;
char gokit_key2down(void)
  int unsigned long keep_time = 0;
  if (digitalRead(KEY2) == LOW)
    delay(100);
      while (digitalRead(KEY2) == LOW) //until open the key
          return KEY2_LONG_PRESS;
        return KEY2_SHORT_PRESS;
      return 0;
    return 0;
  return 0;
char gokit_keydown(void)
  char ret = 0;
  ret |= gokit_key2down();
  ret |= gokit_key1down();
  return ret;
* KEY_Handle
* @param none
* @return none
void KEY_Handle(void)
  /*  Press for over than 3 second is Long Press  */
  switch (gokit_keydown())
    case KEY1_SHORT_PRESS:
      mySerial.println(F("KEY1_SHORT_PRESS , Production Test Mode "));
      myGizwits.setBindMode(WIFI_PRODUCTION_TEST);
      break;
    case KEY1_LONG_PRESS:
      mySerial.println(F("KEY1_LONG_PRESS ,Wifi Reset"));
      myGizwits.setBindMode(WIFI_RESET_MODE);
      break;
    case KEY2_SHORT_PRESS:
      mySerial.println(F("KEY2_SHORT_PRESS Soft AP mode"));
      myGizwits.setBindMode(WIFI_SOFTAP_MODE);
      //Soft AP mode
      break;
    case KEY2_LONG_PRESS:
      mySerial.println(F("KEY2_LONG_PRESS ,AirLink mode"));
      myGizwits.setBindMode(WIFI_AIRLINK_MODE);
      //AirLink mode
      break;
    default:
      break;
* Serial Init , Gizwits Init
* @param none
* @return none
void setup() {
  // put your setup code here, to run once:
  mySerial.begin(115200);
leds.init();
digitalWrite(A0,HIGH);
  pinMode(KEY1, INPUT_PULLUP);
  pinMode(KEY2, INPUT_PULLUP);
pinMode(5,OUTPUT);
  myGizwits.begin();
  mySerial.println("GoKit init  OK \n");
* Wifi status printf
* @param none
* @return none
void wifiStatusHandle()
  if(myGizwits.wifiHasBeenSet(WIFI_SOFTAP))
    mySerial.println(F("WIFI_SOFTAP!"));
  if(myGizwits.wifiHasBeenSet(WIFI_AIRLINK))
    mySerial.println(F("WIFI_AIRLINK!"));
  if(myGizwits.wifiHasBeenSet(WIFI_STATION))
    mySerial.println(F("WIFI_STATION!"));
  if(myGizwits.wifiHasBeenSet(WIFI_CON_ROUTER))
    mySerial.println(F("WIFI_CON_ROUTER!"));
  if(myGizwits.wifiHasBeenSet(WIFI_DISCON_ROUTER))
    mySerial.println(F("WIFI_DISCON_ROUTER!"));
  if(myGizwits.wifiHasBeenSet(WIFI_CON_M2M))
    mySerial.println(F("WIFI_CON_M2M!"));
  if(myGizwits.wifiHasBeenSet(WIFI_DISCON_M2M))
    mySerial.println(F("WIFI_DISCON_M2M!"));
* Arduino loop
* @param none
* @return none
void loop() {
  KEY_Handle();//key handle , network configure
  wifiStatusHandle();//WIFI Status Handle
bool varR_LED = 0;
  if(myGizwits.hasBeenSet(EVENT_LED))
    myGizwits.read(EVENT_LED,&varR_LED);//Address for storing data
    if (varR_LED == 1)
      LED_RGB_Control(200,0,0);
    else
      LED_RGB_Control(0,0,0);
  myGizwits.process();
报错的信息是这个
Arduino:1.8.4 (Windows 8.1), 开发板:"Arduino/Genuino Uno"
In file included from C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\common.c:16:0:
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\common.c: In function 'returnNtp2Wt':
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\common.h:67:23: warning: integer overflow in expression [-Woverflow]
#define DAY_SEC (24*60*60)
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\common.c:246:21: note: in expansion of macro 'DAY_SEC'
         if(utc >= x*DAY_SEC)
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\common.c:248:22: note: in expansion of macro 'DAY_SEC'
             utc -= x*DAY_SEC;
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\common.c:262:27: note: in expansion of macro 'DAY_SEC'
         if(utc >= mons*DAY_SEC)
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\common.c:264:28: note: in expansion of macro 'DAY_SEC'
             utc -= mons*DAY_SEC;
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\common.c:277:19: note: in expansion of macro 'DAY_SEC'
         if(utc >= DAY_SEC)
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\common.c:279:20: note: in expansion of macro 'DAY_SEC'
             utc -= DAY_SEC;
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\gizwits_protocol.c: In function 'gizwitsHandle':
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\gizwits_protocol.c:1243:13: warning: implicit declaration of function 'gizwitsEventProcess' [-Wimplicit-function-declaration]
             gizwitsEventProcess(&gizwitsProtocol.issuedProcessEvent, (uint8_t *)&gizwitsProtocol.gizCurrentDataPoint, sizeof(dataPoint_t));
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:21:13: error: variable or field 'rb_new' declared void
void rb_new(RingBuffer* rb)
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:21:13: error: 'RingBuffer' was not declared in this scope
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:21:25: error: 'rb' was not declared in this scope
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:34:15: error: variable or field 'rb_free' declared void
void  rb_free(RingBuffer *rb)
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:34:15: error: 'RingBuffer' was not declared in this scope
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:34:27: error: 'rb' was not declared in this scope
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:39:24: error: 'RingBuffer' was not declared in this scope
size_t     rb_capacity(RingBuffer *rb)
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:39:36: error: 'rb' was not declared in this scope
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:40:1: error: expected ',' or ';' before '{' token
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:44:24: error: 'RingBuffer' was not declared in this scope
size_t     rb_can_read(RingBuffer *rb)
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:44:36: error: 'rb' was not declared in this scope
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:45:1: error: expected ',' or ';' before '{' token
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:51:25: error: 'RingBuffer' was not declared in this scope
size_t     rb_can_write(RingBuffer *rb)
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:51:37: error: 'rb' was not declared in this scope
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:52:1: error: expected ',' or ';' before '{' token
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:57:20: error: 'RingBuffer' was not declared in this scope
size_t     rb_read(RingBuffer *rb, void *data, size_t count)
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:57:32: error: 'rb' was not declared in this scope
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:57:36: error: expected primary-expression before 'void'
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:57:55: error: expected primary-expression before 'count'
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:57:60: warning: expression list treated as compound expression in initializer [-fpermissive]
C:\Users\Administrator\Documents\Arduino\libraries\Gizwits\ringbuffer.cpp:58:1: error: expected ',' or ';' before '{' token
exit status 1
为开发板 Arduino/Genuino Uno 编译时出错。
在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
感觉不该有问题才对啊
求前辈们指点
30分钟基于arduino开发一个智能灯.zip (1.52 MB, 下载次数: 1)
错误信息.rar (1.15 KB, 下载次数: 0)
我的代码.rar (1.59 KB, 下载次数: 0)
