查看: 5334|回复: 0
QT quick
38
发表于 2016-9-2 16:22:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The Qt Quick module is the standard library for writing QML applications. While the Qt QML module provides the QML engine and language infrastructure, the Qt Quick module provides all the basic types necessary for creating user interfaces with QML. It provides a visual canvas and includes types for creating and animating visual components, receiving user input, creating data models and views and delayed object instantiation.
The Qt Quick module provides both a QML API which supplies QML types for creating user interfaces with the QML language, and a C++ API for extending QML applications with C++ code.
Note: A set of Qt Quick-based UI controls is also available to create user interfaces. See Qt Quick Controls for more information.
For those new to QML and Qt Quick, please see QML Applications for an introduction to writing QML applications.
Important Concepts in Qt Quick
Qt Quick provides everything needed to create a rich application with a fluid and dynamic user interface. It enables user interfaces to be built around the behavior of user interface components and how they connect with one another, and it provides a visual canvas with its own coordinate system and rendering engine. Animation and transition effects are a first class concept in Qt Quick, and visual effects can be supplemented through specialized components for particle and shader effects.
When using the QtQuick module, you will need to know how to write QML applications using the QML language. In particular, QML Basics and QML Essentials from the QML Applications page.
To find out more about using the QML language, see the Qt QML module documentation.
C++ Extension PointsReference Documentation
Additional Qt Quick information:
  • Qt Quick C++ Classes - the C++ API provided by the Qt Quick module
  • Qt Quick QML Types - a list of QML types provided by the QtQuick import
    • XML List Model - contains types for creating models from XML data
    • Local Storage - a submodule containing a JavaScript interface for an SQLite database
    • Particles - provides a particle system for Qt Quick
    • Layouts - provides layouts for arranging Qt Quick items
    • Window - contains types for creating top-level windows and accessing screen information
    • Dialogs - contains types for creating and interacting with system dialogs
    • Tests - contains types for writing unit test for a QML application
  • Qt Quick Examples and Tutorials
Further information for writing QML applications:
  • QML Applications - essential information for application development with QML and Qt Quick
  • Qt QML - documentation for the Qt QML module, which provides the QML engine and language infrastructure
C++ GUI Qt4 编程 (第二版)带书签Qt及Qt Quick开发实战精解
Qt Creator快速入门
精通Qt4编程
QT项目
QT高级编程
