查看: 214587|回复: 2
[求助] mega2560和nodemcu问题
 楼主| 发表于 2020-4-20 22:56:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. /**
  2. ****************************************
  3. * @file         Gizwits + arduinoUnoR3 Library
  4. * @brief        Datapoints handle , Gizwits Process
  5. * @author       Gizwits
  6. * @date         2017-08-01
  7. * @version      V03030000
  8. * @copyright    Gizwits
  9. *
  10. * @note         机智云.只为智能硬件而生
  11. *               Gizwits Smart Cloud  for Smart Products
  12. *               链接|增值ֵ|开放|中立|安全|自有|自由|生态
  13. *               www.gizwits.com
  14. *
  15. ****************************************/
  16. #include "Gizwits.h"
  17. //#include <Wire.h>
  18. #include <SoftwareSerial.h>
  19. //#include"gizwits_product.h"
  20. //#include"gizwits_protocol.h"
  21. //#include<dataPointTools.h>
  22. //SoftwareSerial mySerial(18, 19); // A2 -> RX, A3 -> TX
  23. Gizwits myGizwits;
  24. //Wifi配网
  25. void wifiStatusHandle()
  26. {
  27.   if(myGizwits.wifiHasBeenSet(WIFI_CON_ROUTER)){}
  28. }
  29. /**
  30. * Serial Init , Gizwits Init
  31. * @param none
  32. * @return none
  33. */
  34. void setup() {
  35.   // put your setup code here, to run once:
  36.   mySerial.begin(115200);
  37.   //Serial.begin(9600);
  38.   myGizwits.begin();
  39.   //Serial.println("gokit init  OK \n");
  40. }
  41. /**
  42. * Arduino loop
  43. * @param none
  44. * @return none
  45. */
  46. float varW_temp = 0;//Add Sensor Data Collection
  47. void loop() {
  48.
  49.   //Configure network
  50.   //if(XXX) //Trigger Condition
  51.   //myGizwits.setBindMode(0x02);  //0x01:Enter AP Mode;0x02:Enter Airlink Mode
  52.
  53.
  54.   myGizwits.write(VALUE_temp, varW_temp);
  55.   float varW_shidu = 50;//Add Sensor Data Collection
  56.   myGizwits.write(VALUE_shidu, varW_shidu);
  57.
  58.   varW_temp+=1;
  59.   //delay(500);
  60.   //Serial.println(varW_temp);
  61.
  62.   if(varW_temp>30){
  63.     varW_temp=0;
  64.   }
  65.
  66.   unsigned long varR_xinlv = 0;
  67.   if(myGizwits.hasBeenSet(EVENT_xinlv))
  68.   {
  69.     myGizwits.read(EVENT_xinlv,&varR_xinlv);//Address for storing data
  70.     //Serial.println(F("EVENT_xinlv"));
  71.     //Serial.println(varR_xinlv,DEC);
  72.
  73.   }
  74.   //binary datapoint handle
  75.
  76.   wifiStatusHandle();
  77.   myGizwits.process();
  78. }
数据上传失败,服务器显示设备在线了,但是一直无法收到数据
 楼主| 发表于 2020-4-20 22:57:15 | 只看该作者
用的代码是mcu生成unor3的simpleTry代码
发表于 2021-5-4 16:24:14 | 只看该作者
请问楼主解决了吗?我这里连接机智云接不上。和你一样的硬件。解决了能指点下吗
