查看: 30508|回复: 2
sae获取 token
发表于 2016-4-17 23:20:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
  1. <?php
  2. function curl_post($url,$data='',$timeout=30,$header=array()){
  3.         $arrCurlResult = array();
  4.         $ch = curl_init();
  5.         curl_setopt($ch, CURLOPT_HTTPHEADER, $header);
  6.         curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, true);//ssl检测跳过
  7.         curl_setopt($ch, CURLOPT_URL, $url);
  8.         curl_setopt($ch, CURLOPT_POST, true);
  9.         curl_setopt($ch, CURLOPT_POSTFIELDS,$data);
  10.         curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
  11.         curl_setopt($ch, CURLOPT_HEADER, false);
  12.         curl_setopt($ch, CURLOPT_TIMEOUT, $timeout);
  13.         curl_setopt ( $ch,CURLOPT_REFERER,"");
  14.         $output = curl_exec($ch);
  15.         $responseCode = curl_getinfo($ch,CURLINFO_HTTP_CODE);
  16.         $arrCurlResult['output'] = $output;//返回结果
  17.         $arrCurlResult['code'] = $responseCode;//返回http状态
  18.         curl_close($ch);
  19.         unset($ch);
  20.         return $arrCurlResult;
  21. }
  22. $header=array(
  23.         'Content-Type: application/json',
  24.         'X-Gizwits-Application-Id: 46a40ad548aa47398a335c5a97390fa8'//appid隐藏了
  25. );
  26. $params=array(
  27.         "phone_id"=> "apiary"
  28. );
  29. $params_query=json_encode($params);
  30. echo $params_query;
  31. $result=@curl_post('http://api.gizwits.com/app/users',$params_query,30,$header);
  32. echo '<pre>';
  33. print_r($result);
  34. ?>
屏幕快照 2016-04-24 下午5.59.02.png (332.54 KB, 下载次数: 925)
推荐
发表于 2016-4-27 15:32:00 | 只看该作者
>      --header "X-Gizwits-Application-Id: {46a40ad548aa47398a335c5a97390fa8}" \
这里appid是不需要大括号的{}
