查看: 72740|回复: 1
[求助] 读取两个模拟量的时候只能准确读到一个数据,求助大神啊
发表于 2017-4-6 17:42:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
__IO uint16_t ADC_ConvertedValue[2]={0,0};
#define ADC1_DR_Address ((u32)0x40012400+0x4c)
*   配置DMA1
*   add by alex.lin --2014-12-5
static void ADC1_GPIO_Config(void)
    GPIO_InitTypeDef GPIO_InitStructure;
    /* 使能DMA时钟 */
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    /*使能ADC1,GPIOA时钟 */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOA, ENABLE);
    /*配置PA4,PA5为模拟输入 */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_4;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
*   配置DMA1
void  DMA1_Config(void)
    DMA_InitTypeDef DMA_InitStructure;
    DMA_DeInit(DMA1_Channel1);
    DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;//ADC1_DR_Address;
    DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue; //定义DMA通道存储器地址
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;           //指定外设为源地址
    DMA_InitStructure.DMA_BufferSize = 2;            //        定义DMA缓冲区大小2
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;        //当前外设寄存器地址不变
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;     //          内存地址自动增加
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;           //定义外设数据宽度16位
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;                         //定义存储器数据宽度16位
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);
    DMA_Cmd(DMA1_Channel1, ENABLE);
*   配置ADC
static void ADC1_Mode_Config(void)
    ADC_InitTypeDef ADC_InitStructure;
    DMA1_Config();
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;         //ADC1和ADC2工作在独立模式
    ADC_InitStructure.ADC_ScanConvMode = ENABLE ;                  //多通道
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;                //ADC转换工作在连续模式
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;          //由软件控制转换
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;                          //转换数据右对齐
    ADC_InitStructure.ADC_NbrOfChannel = 2;                         //转换通道数目为2,一路土壤湿度,一路光线强度
    ADC_Init(ADC1, &ADC_InitStructure);
    RCC_ADCCLKConfig(RCC_PCLK2_Div8);
    //设置采样周期
    ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 1, ADC_SampleTime_55Cycles5);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 2, ADC_SampleTime_55Cycles5);
    ADC_DMACmd(ADC1, ENABLE);       //使能ADC1模块的DMA
    ADC_Cmd(ADC1, ENABLE);           //使能ADC1
    ADC_ResetCalibration(ADC1);                         //重置ADC1校准重置完成
    while(ADC_GetResetCalibrationStatus(ADC1));                        //等待ADC1校准重置完成
    ADC_StartCalibration(ADC1);                                   //开始ADC1校准
    while(ADC_GetCalibrationStatus(ADC1));           //等待ADC1校准完成
    ADC_SoftwareStartConvCmd(ADC1, ENABLE);           //软件使能ADC1开始转换
*   配置DMA1
void ADC1_Init(void)
    ADC1_GPIO_Config();
    ADC1_Mode_Config();
求大神指点一下哪里有问题,只能读到PA5的数据
27
发表于 2017-4-8 16:00:20 | 只看该作者
ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 1, ADC_SampleTime_55Cycles5);         ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 2, ADC_SampleTime_55Cycles5);这里使用或运算试试
