查看: 130559|回复: 1
[求助] 机智云串口租售无法使wifi进入配置模式
发表于 2018-12-14 22:01:16 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
机智云串口租售无法使wifi进入配置模式,不知道为什么使用机智云串口助手就是不好用,连接8266后也无法配置,
求教哪位好心的大神帮忙解决一下,万分感激!!!!
#include "STC15W4K.H"      // 包含 "STC15W4K.H"寄存器定义头文件
#include<intrins.h>
#define uchar unsigned char
#define uint  unsigned int
sbit lcd0=P1^1;
sbit key_config_Ap=P1^2;
sbit key_config_Air=P1^3;
idata uchar rece_buf[32],comm_dat[32],temper;
idata uchar sn,checksum;
idata uchar recFlag;
idata uchar mainclock=0;
idata uchar mainsec = 0;
idata uchar num=0;           // 存放接收到的1个字节的数据
idata uchar recevdatapm = 0;
idata uchar usrtlen = 0;
idata uchar usartbuf[32]=0;
idata uchar uart_num=0;
idata uchar usarrtflag = 0;
idata uchar endflag = 0;
idata uchar comm_len=0;
uchar ButtonFlag = 0;
uchar send_3_config,send_7_error,send_8_dev,send_9_dev;
/*wifi模组请求设备信息,mcu回复*/
uchar mcu_send_1[75]={
0xff,0xff,0x00,0x47,0x02,0x55,0x00,0x00,
0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x34,
0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x31,
0x35,0x65,0x33,0x66,0x62,0x61,0x37,0x32,
0x34,0x32,0x33,0x61,0x34,0x63,0x36,0x63,
0x62,0x38,0x37,0x39,0x33,0x38,0x39,0x39,
0x62,0x61,0x61,0x66,0x31,0x35,0x38,0x30,
0x00,0x00,0x55};
/*wifi模组与设备mcu心跳,mcu回复*/
uchar mcu_send_2[9]={0xff,0xff,0x00,0x05,0x08,0x55,0x00,0x00,0x55};
/*设备mcu通知wifi模组进入配置模式,mcu发送*/
uchar mcu_send_3[10]={0xff,0xff,0x00,0x06,0x09,0x55,0x00,0x00,0x02,0x55};
/*设备mcu重置wifi,mcu发送*/
uchar mcu_send_4[9]={0xff,0xff,0x00,0x05,0x0b,0x55,0x00,0x00,0x55};
/*wifi模组向设备通知工作状态变化,mcu回复*/
uchar mcu_send_5[9]={0xff,0xff,0x00,0x05,0x0e,0x55,0x00,0x00,0x55};
/*wifi模组请求重启mcu,mcu回复*/
uchar mcu_send_6[9]={0xff,0xff,0x00,0x05,0x10,0x55,0x00,0x00,0x55};
/*非法消息通知,mcu回复*/
uchar mcu_send_7[10]={0xff,0xff,0x00,0x06,0x12,0x55,0x00,0x00,0x11,0x55};
/*wifi模组读取设备当前状态,mcu回复*/
uchar mcu_send_8[11]={0xff,0xff,0x00,0x07,0x04,0x55,0x00,0x00,0x03,0x11,0x55};
/*设备向wifi主动上报当前状态,mcu发送*/
uchar mcu_send_9[11]={0xff,0xff,0x00,0x07,0x05,0x55,0x00,0x00,0x04,0x11,0x55};
/*wifi模组控制设备,mcu回复*/
uchar mcu_send_10[9]={0xff,0xff,0x00,0x05,0x04,0x55,0x00,0x00,0x55};
/*mcu通知wifi进入可绑定模式,mcu发送*/
uchar mcu_send_12[9]={0xff,0xff,0x00,0x05,0x15,0x55,0x00,0x00,0x55};
/*延时函数*/
void Delay_ms(unsigned char z)
        unsigned char x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void MEMCOPY(uchar *dest,uchar *src,uint len)
        while(len--)
                *dest++ = *src++;
/*mcu发送数据程序*/
void Usart_SendArrang(uchar *dat,uchar len)
        unsigned char i;
        for(i=0;i<len;i++)
                        ES=0;
                        SBUF=dat[i];
                        while(!TI);
                        TI=0;
                        ES=1;
- 功能描述:51单片机的串口发送字节的函数
- 隶属模块:STC51串口操作
- 函数属性:外部,使用户使用
- 参数说明:mydata:要发送的一个字节
- 返回说明:无
- 注:发送一个字节,是串口发送的基础操作
void UART_Send_Byte(unsigned char mydata)
ES=0;
TI=0;
SBUF=mydata;
while(!TI);
TI=0;
ES=1;
- 功能描述:51单片机的串口发送字符串
- 隶属模块:STC51串口操作
- 函数属性:外部,使用户使用
- 参数说明:s:指向字符串的指针
- 返回说明:无
void UART_Send_Str(char *s)
int i=0;
while(s[i]!=0)
        UART_Send_Byte(s[i]);
        i++;
void uart_int(void)
{  // 下面代码设置定串口1
        T2H  = 0xFE;        // 波特率:9600 /22.1184MHZ,1T
        T2L  = 0xE0;        // 波特率:9600 /22.1184MHZ,1T
        AUXR = 0x15;    // 0001 0101,T2R=1启动T2运行,T2x12=1,定时器2按1T计数,S1ST2=1
        SCON = 0x50;         // 0101 0000 SM0.SM1=01(最普遍的8位通信),REN=1(允许接收)
        AUXR1 |= 0x40;
  // 下面代码设置定时器中断
        TMOD = 0x01;        //设置定时器模式
        TL0 = 0xB0;                //设置定时初值
        TH0 = 0x3C;                //设置定时重载值
        ET0 = 1;                //清除TF0标志
        TR0 = 1;                //定时器0开始计时
        ES   = 1;                // 开串口1中断
        EA   = 1;                // 开总中断
void Usart_Communication()
        uchar i;
        if(mainclock==10)
                ET0=0;
                mainclock=0;
                usarrtflag=1;
                REN=0;
        if(usarrtflag)
                sn=usartbuf[5];
                checksum=0;
                switch(usartbuf[4])
                        case 0x01:
                                mcu_send_1[5]=sn;
                                for(i=2;i<74;i++)
                                        checksum=checksum+mcu_send_1[i];
                                checksum=checksum%256;
                                mcu_send_1[74]=checksum;
                                Usart_SendArrang(mcu_send_1,75);
                                break;
                        case 0x07:
                                mcu_send_2[5]=sn;
                                for(i=2;i<8;i++)
                                        checksum=checksum+mcu_send_2[i];
                                mcu_send_2[8]=checksum;
                                Usart_SendArrang(mcu_send_2,9);
                                break;
                        case 0x0a:
                                break;
                        case 0x0c:
                                break;
                        case 0x0d:
                                mcu_send_5[5]=sn;
                                for(i=2;i<8;i++)
                                        checksum=checksum+mcu_send_5[i];
                                mcu_send_5[8]=checksum;
                                Usart_SendArrang(mcu_send_5,9);
                                break;
                        case 0x0f:
                                mcu_send_6[5]=sn;
                                for(i=2;i<8;i++)
                                        checksum=checksum+mcu_send_6[i];
                                mcu_send_6[8]=checksum;
                                Usart_SendArrang(mcu_send_6,9);
                                break;
                        case 0x11:
                                mcu_send_7[5]=sn;
                                send_7_error=usartbuf[8];
                                mcu_send_7[8]=send_7_error;
                                for(i=2;i<9;i++)
                                        checksum=checksum+mcu_send_7[i];
                                mcu_send_7[9]=checksum;
                                Usart_SendArrang(mcu_send_7,10);
                                break;
                        case 0x03:
                                if(usartbuf[3]=0x06&&usartbuf[8]==0x02)
                                        mcu_send_8[5]=sn;
                                        send_8_dev=~P1;
                                        mcu_send_8[9]=send_8_dev;
                                        for(i=2;i<10;i++)
                                                checksum=checksum+mcu_send_8[i];
                                        mcu_send_8[10]=checksum;
                                        Usart_SendArrang(mcu_send_8,11);
                                        break;
                                if(usartbuf[3]=0x08&&usartbuf[8]==0x01)
                                        //Control_Mcu();        //收到数据后,mcu控制设备函数
                                        mcu_send_10[5]=sn;
                                        for(i=2;i<8;i++)
                                                checksum=checksum+mcu_send_10[i];
                                        mcu_send_10[8]=checksum;
                                        Usart_SendArrang(mcu_send_10,9);                        //mcu回复
                                        mcu_send_9[5]=sn;
                                        send_9_dev=~P1;
                                        mcu_send_9[9]=send_9_dev;
                                        for(i=2;i<10;i++)
                                                checksum=checksum+mcu_send_9[i];
                                        mcu_send_9[10]=checksum;
                                        Usart_SendArrang(mcu_send_9,11);                        //mcu主动上报设备状态
                                        break;
                        case 0x06:
                                break;
                        case 0x16:
                                break;
                usrtlen=0;
                usarrtflag=0;
                REN=1;
/*按键配置设备入网*/
void Key_Usart_Config()
        uchar i;
        checksum=0;
        if(key_config_Ap==0)        //SoftAp配置模式
                Delay_ms(10);
                        REN=0;
                        sn=0x00;
                        mcu_send_3[5]=sn;
                        for(i=2;i<9;i++)
                                checksum=checksum+mcu_send_3[i];
//                        mcu_send_3[9]=checksum;
//                        send_3_config=1;
//                        mcu_send_3[8]=send_3_config;
                        Usart_SendArrang(mcu_send_3,10);
                        while(key_config_Ap==0);
                        REN=1;
        if(key_config_Air==0)        //AirLink配置模式
                Delay_ms(100);
                Delay_ms(100);
                        REN=0;
                        sn=0x00;
                        mcu_send_3[5]=sn;
                        for(i=2;i<9;i++)
//                        send_3_config=2;
                        while(key_config_Air==0);
                        REN=1;
void main()
   uart_int();
   while(1)
     //定时器1:1S
                if(mainclock==30)
                         mainsec = 1;
                     mainclock= 0;
             switch(usartbuf[9])
                        case 0x01:
                                if(usartbuf[10]==0x01)
                                        lcd0=0;
                                else if(usartbuf[10]==0)
                                        lcd0=1;
                                break;
                        default:
                                break;
                Key_Usart_Config();
                Usart_Communication();
//定时器中断
void time0_int(void) interrupt 1  // 串行口1中断函数
    mainclock++;
//串口中断
void UART1(void) interrupt  4//串口中断接收函数
      mainclock=0;
        ET0=1;
        usartbuf[usrtlen++]=SBUF;
        if(usrtlen==2)
                if(usartbuf[0]!=0xff||usartbuf[1]!=0xff)
                        usrtlen=0;
        RI=0;
百无一用是书生
发表于 2018-12-18 09:50:15 | 只看该作者
回帖奖励 +3
下载程序的时候注意晶振大小是否合程序匹配,不匹配会导致波特率差异
发烧友
