查看: 125708|回复: 4
[求助] 心跳正常,MCU只发0X05命令,不回,其它命令正常回
20
发表于 2016-9-6 21:19:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
GAgent for esp8266 04020014
DEV_CountDown_Minute Check Changed
changed, report data
MCU2WiFi[1817978:  29]: ff ff 00 19 05 7d 00 00 04 04 7f 05 a0 03 d9 ff f6 00 09 06 15 05 27 38 00 00 07 e0 07
Warning:protocolResendData 1821011 1818010 0
Warning: timeout, resend data
MCU2WiFi[1821018:  29]: ff ff 00 19 05 7d 00 00 04 04 7f 05 a0 03 d9 ff f6 00 09 06 15 05 27 38 00 00 07 e0 07
Warning:protocolResendData 1824051 1821050 1
MCU2WiFi[1824058:  29]: ff ff 00 19 05 7d 00 00 04 04 7f 05 a0 03 d9 ff f6 00 09 06 15 05 27 38 00 00 07 e0 07
Warning:protocolResendData 1827091 1824090 2
MCU2WiFi[1827098:  29]: ff ff 00 19 05 7d 00 00 04 04 7f 05 a0 03 d9 ff f6 00 09 06 15 05 27 38 00 00 07 e0 07
Get One Packet!
WiFi2MCU[1865802:   9]: ff ff 00 05 07 63 00 00 6f
MCU2WiFi[1865807:   9]: ff ff 00 05 08 63 00 00 70
MCU2WiFi[1877984:  29]: ff ff 00 19 05 7e 00 00 04 04 7f 05 a0 03 d9 ff f5 00 09 06 15 05 27 38 00 00 07 e0 07
Warning:protocolResendData 1881017 1878016 0
MCU2WiFi[1881024:  29]: ff ff 00 19 05 7e 00 00 04 04 7f 05 a0 03 d9 ff f5 00 09 06 15 05 27 38 00 00 07 e0 07
Warning:protocolResendData 1884057 1881056 1
MCU2WiFi[1884064:  29]: ff ff 00 19 05 7e 00 00 04 04 7f 05 a0 03 d9 ff f5 00 09 06 15 05 27 38 00 00 07 e0 07
Warning:protocolResendData 1887097 1884096 2
MCU2WiFi[1887104:  29]: ff ff 00 19 05 7e 00 00 04 04 7f 05 a0 03 d9 ff f5 00 09 06 15 05 27 38 00 00 07 e0 07
Get One Packet!
WiFi2MCU[1955316:  19]: ff ff 00 0f 03 67 00 00 01 01 01 00 00 00 00 00 00 00 7c
MCU2WiFi[1955323:   9]: ff ff 00 05 04 67 00 00 70
Evt: START_OnOff = 1
DEV_OnOff Check Changed
MCU2WiFi[1955340:  29]: ff ff 00 19 05 80 00 00 04 05 7f 05 a0 03 d9 ff f4 00 09 06 15 05 27 38 00 00 07 e0 09
推荐
发表于 2016-9-7 11:22:43 | 只看该作者
肯定是命令错了。好好对下接入文档。
20
 楼主| 发表于 2016-9-6 21:22:41 | 只看该作者
重启后,连接上网络才恢复正常
Get One Packet!
20
 楼主| 发表于 2016-9-6 21:23:09 | 只看该作者
Get One Packet!
WiFi2MCU[56273:  19]: ff ff 00 0f 03 09 00 00 01 01 00 00 00 00 00 00 00 00 1d
MCU2WiFi[56280:   9]: ff ff 00 05 04 09 00 00 12
Evt: START_OnOff = 0
MCU2WiFi[56297:  29]: ff ff 00 19 05 06 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 38 00 00 00 00 60
Get One Packet!
WiFi2MCU[56341:   9]: ff ff 00 05 06 06 00 00 11
Get One Packet!
20
 楼主| 发表于 2016-9-7 12:14:26 | 只看该作者
话可不能说得这么满,上面打印的信息你验证一下。看看有没有错的,我随机校验一下,校验码没有问题。命令是正确的,重启一下模块,就正常了。重启一下模块,就正常了。重启一下模块,就正常了。
